On one of my JJ 300B's there is a loose pin. (see pics)
Any idea how to fix this?
Thanks,
Jim
Insert into socket and don't worry about it . Fix the issue with a new 300B once this one goes bad
316A
Don't listen to the above posts.
First you must remove the base of the tube. Using a pair of pliers to grip the base, hold the tube tightly and rotate the base until it comes off. This may require some amount of force but don't be concerned.
Once the tube shatters into a million pieces from the unsuccessful attempt to remove the base order a new tube.
- Tubes / Valves
- Loose pin on a JJ 300B
