900W H-class PA Amp with Limiter
h900
good to go
Ready for wiring
@Mile Hello
Im having problem with my PSU i got unbalance -/+dc on medium voltage with out load
120vdc 60vdc 0 63vdc 120vdc is it safe to load the 2 H900
as long as your output offset voltage remains low or nearly 0, i seen no problem......
the tapping on your power traffo was innacurately done, that is why i do all my traffos with bifilliar wound secondaries, so that turns count is kept accurate....
H900 testing
@Mile GOOD DAY
1 channel now working, voltage rails for testing 75/44/0/44/75 -/+
feed 50hz and 100 hz in full volume without load clip indacator is glow permanent, i just use analog multimeter to test ac voltage on output Pls see some picture....
I load some Speaker and Superb Sound<><
2Channel H900 fired up
Happy holidays to all
2Channel of H900 is now fired up and Great HiFi sounds
next action install Apex Protect circuit and the right Trapo to check Heat and power
TY MILE!!
