Could somebody please tell me the bias setting for the R-1.5? I've one of these amps which required the output stage repairing, the emitter resistors came off the solder joints and shorted out onto the heatsinks
Its had a full set of output transistors fitted
I don't think the Usher have one more stage.
Only difference seen is in the LVA, which is a differential stage, instead of single in the S300, but, why differential, if the second output is used for nothing? maybe more loop gain?
wait a minute did I hear right , the new Usher products have motorola outputs? ummm that is interesting where are they finding that many NOS parts? Motorola semi's became Onsemi a long time ago. Anything new with a motorola logo is most assuredly a fake.
Or did I not understand what you were saying?
The output devices in the Usher I have here are On-semi
One channel suffers from thermal runaway , it starts at around 300mA and shoots past 3A
georgehifi said:
moe, yes the circuit is posted, back on post 6 of this thread, it has an extra gain stage which makes the amp a little more dynamic than the original S300 II Threshold. As if the the s300 had an Achilles heal it was a little slow/soft sounding.
This seems to have addressed the probelm all else is basically the same except for the bias, Usher ran it at half the bias of the original S300/S500 mkII's even Nelson commented that it would help if it were biased up harder into Class A as this circuit can benifit from that. Here is the circuit again of the R2.5 Usher
Cheers George
Hello George,
I am new to this thread but have enjoyed reading it. You seem to be an advocate for the Usher Audio R-2.5. I am in desperate need for lots of power for my dynaudio Confidence 5 speakers, which are currently fed by a NAD M3 intergrated. Though the M3 sounds pretty good it doesn't seem to be able to push the bass driver of the C5 enough to produce an accurate sound image. While I was doing my research on potential used power amps to consider as a replacement for the M3 I found this thread talking about all the amplifiers I am interested in- Threshold, Nakamichi P7mk2 Stasis, Pass X250, Usher R-2.5. They all have one thing in common- Nelson Pass design, right?! I am under the impression that the Usher is a remarkable piece of amplification and am tempted to give it a try over the Nak Stasis or the Threshold. But how would you rate it against the Pass X250?
I would highly appreciate a word of wisdom! Thanks
I wouldn't comment unless I lived with both, I would say though the X250 is not the same design I think (Nelson will probably help here) as the Usher 2.5 the Usher is a close copy of the older Threshold S300mkII. So you would think that the X250 having Nelsons later circuitry it will have the better sound.
Funny you should bring up the Usher thread again a friend said there's a 2.5 going either on ebay or audiogone yesterday for just $1000us.
Cheers George
Cheers George
Actually if you compare the Usher schematic posted here against the
Threshold schematics, you will see that there are quite a few differences.
The Usher has a different front end - it is biased by different current sources
and uses current mirrors off the input stage and has a differential VAS. The
first does not regulate as well, and the last two create a higher open loop
gain (for more feedback). The bias system is different and is placed after
the drive stage, not before.
The output stage is pretty similar though.
You may prefer the Usher, but I would not call it a close copy.
georgehifi said:I wouldn't comment unless I lived with both, I would say though the X250 is not the same design I think (Nelson will probably help here) as the Usher 2.5 the Usher is a close copy of the older Threshold S300mkII. So you would think that the X250 having Nelsons later circuitry it will have the better sound.
Cheers George
Thanks to both of you, George & Nelson, for your replies. You guys rock! Indeed there is an Usher 2.5 for sale right now on ebay- currently the bid is at $1650 USD. One more day to go. It will probably end above $2k I assume. Maybe I should shop around for a used X250 instead. I just replaced my power cord on the NAD M3 with a brand new PS-Audio AC-5, they just started to ship those. Couldn't believe my ears what a difference that new power cord makes. The Amp sound a lot more dynamic and pushes the bass on my C5 with a much stronger impulse, wow! I strongly recommend their new power cords.
ArneD
Anybody heard about the Usher R-3.0 ? Any body know the price ? There is one for sale in Oslo ( Norway ) and I consider to buy it. First thing I will do is to remove all the terminal blocks and solder evrything.
usher 3.0
Hi, have 1 of these usher 3.0 amp, and wondering about buying 1 more, for brigde use/monos.. What do you experts think? Will it increase the overall performance, ore is it just waist..?😕 The speakers are usher be 20s..
Best reg
Yel
Best reg
Yel
Yes, they are in Taipei, Taiwan. I was walking around Taipei 10 years ago on a business trip and walked by their store. When I went in and saw their amps, it was immediately obvious to me that these were Threshold clones, at least from the outside. They did have one open and I was impressed by their construction and craftsmanship.Usher, I think is based in Taiwan(?)...it looks like they're as shy as DIYZone.
Tom.
Bias setting Usher 1.5
Hi all,
Has anyone any information as to what the bias setting should be on this amplifier.
John Caswell
Hi all,
John Caswell
I would set the bias so that after a couple hours operation the
heat sink temperature settles into 50 deg C (ten second hand-
on-sink test)
on-sink test)
Hi Nelson,
Many thanks, a nice practical answer that I can translate accordingly.
John
Hi Nelson,
John
Hi there i am new here and own since last year a Forté a1 with a Forté model 2, both bought from the first owners, both from Germany. I also have a DIY B1, bought from the own that build it, and I prefer the sound and the transparacy of the B1 but also like the balls of the model 2. A question, i would prefer a bit more bass from my SF Extrema's, the sound is very open and clear with very good artecultion also in the lower registers, but i would like a bit more push. Can somebody give me an advice, could extra coupling caps (quality caps ) on the power caps (the big electrolyt one's) bring more push?
Thx for a helping hand in these. Grtz Ruud
- Are Usher amps just lookalike or buildt on licence?
