I wonder if the Usher R-1.5, R-2.5, R-2.8 and R-3.0 amps that look almost identical to older Threshold designs, are buildt on license from Mr. Nelson Pass or if they are copies.
Here is the Usher, and next post is the Stasis, i've worked on the Usher and it's quality and build is exceptional. The only thing is that they run them at half the class A bias that Nelson did. I suppose that considering where they come from (Asia) it's practical not to have a hot idling amp. I own the Threshold S300 mkII optical and the Usher is very close, i'd say they may have paid for the Stasis licence.
Cheers George
Cheers George
Thanks for the info,
do you know the answer on my other post where I ask if my X350 lacks power?
Dag🙂
Dag🙂
Nelson should be able to answer that better than i can, (and he will he never misses a beat) but that is one serious nasty load at 30hz, wonder what the phase angle is also at that frequency, i've heard that some of the higher end Infinitys were a real b**** to drive especially the earlier RS4.5's and such.
Cheers George
Cheers George
OK, I am waiting for him to see and reply to my post, do you know how long I should expect to wait before I rephrase the heading and post it again?
Dag🙂
Dag🙂
I bet Nelson is torturizing one of his X350's at this very moment.dagjohnsen said:OK, I am waiting for him to see and reply to my post, do you know how long I should expect to wait before I rephrase the heading and post it again?
Dag🙂
/Hugo 🙂
dagjohnsen said:do you know the answer on my other post where I ask if my X350 lacks power?
Well, it delivers what we say it does. Is 350 watt/ch not
enough? It should peak around 800 into 2 ohms given the
20A output rating.
HBarske said:The similarities are purely optical. Electronically, they are completely different.
The output stage is the same as some of the Threshold, but
they look to have stuck an additional gain stage in the middle.
In any case, the patent has expired and belongs to someone
else. Usher doen't appear to be shy about copying popular
circuits, but it's too bad if they run it at half bias, as the
performance was very dependent on full bias.
I have no doubt that the amp delivers 350 watts🙂
But if it is a bad thing that the VU meters bottoms out (and clipping occurs) then it seems like I need even more.
Probably the wise thing to do is to go all the way to the X1000 monos.
Another solution is to get one more X350 and biamp. (one for the bass, one for the top) maybe a good thing because of the 1,5 ohm impedance drop @30 hz.
Dag
Dag
Usher, I think is based in Taiwan(?)...it looks like they're as shy as DIYZone.
hello georgehifi, could you give me your full opinion of the sound and build quality of the usher r-1.5 amp?
I've been inside the 2.5, and it has stunning build quality, better than the Thresholds of yesteryear, if I did'nt know better, I'd say it was built by Nelson today with the modern day maufacturing.
Nelson would be proud if he saw them, and was getting a kickback naturally.
All componentry (caps, resistors, transistors, circuit boards) look first rate, transformer are huge and a work of art, they have a beautiful chassis and massive heatsinks that run luke warm and need to be biased up harder to sound even better than they already sound. Maybe the reason they run so cool is that they wanted them bullit-poof even if power up in the Sahra or some desert.
Well worth considering if you can get a secondhand one cheap.
In my oppinion they've out Krelled, Krell in construction and build quality
Cheers George
Cheers George
Just search the web for Usher amplifiers.
Completely copying the 80s S-series exterior look may have been one reason for Threshold the sequel to re-issue an oldy.
- Are Usher amps just lookalike or buildt on licence?
