lets discuss Karlson
So, I suggest that with the long cut you no longer have much loading of any sort and the "Q" of the system is greatly reduced, thus the ripples are also reduced.
Look at that graph under the heading "Direct Comparison." Loading for the k-tube and the angle-cut tube appear nearly identical. (Though the tester notes that there might be some variance in proximity effect, mostly between the uncut tube and the other two).
I agree that an impedance sweep would tell a lot.
Here's an interesting post on the Karlson forum:
Made some experiments with my tractrix tube (changing the slot a bit, making the whole tube longer with about 4" closed tube at the driver.
This is getting interesting. The measurement is at one point this time, 2m above the tube, 25° to the axis of the tube. I would also say it's louder now...
Smoothing is 1/24oct
I can't believe the phase. If this is correct, it would be awesome. Also the group delay is within 1ms.
btw here's some K-projects by Carl - a one-10" Karlson type subwoofer augmented his 8-10" Scan-speak midbasses
Hi all. I've built a pair of K-15 about 20 years ago, and with a half decent amp, they make my walls rattle. I've put in 15" StudioLab drivers in the cabs, and horn 12" mid and piezo tweeter. At 103db 1/watt-meter, I'm happy.
Hi Audio Buff
I'm pleased to hear your Karlson K15's are keeping the local plasterers busy !
103 dB for 1 Watt is brilliant efficiency, thanks to the Karlson.
What kind of 12" mid horn did you use, with the 'Ultra Fidelity Enclosure', is it top mounted ?
Do you have any photos of your Karlson build ?
Cheers
Simon
Hi freddi!
I've been reading your input over on Magnetar's thread about his OB's and got interested about "the Tube" (k-slot tweeter).
I'm working something up that will be an OB - but not as big as Magnetar's :bawling: (can't afford THAT). Chops has an interesting prototype over on his thread but it uses a very big horn that presents a space problem for me. 🙄
I want to toss together one of your "K-Tubes" (do you have a name that you prefer to have them called?) for HF and intend to use the B&C DE10-8. PE has the Eminence APT-3 adapters as well but this is where things start to get a little fuzzy for me. How to mate the driver plus adapter to the K-slot. :scratch: Maybe when I have the parts I will have a BFO (Brilliant Flash of the Obvious :bulb: ) and thing will seem clear - buuuuttt you have already been there - done that - and thus the question. I have a Dremel set and understand your drawing posted at Magnetar's site - so no problem making the tube - I'm just unclear on how to assemble the parts. I'll be glad to post some photo's as I go along if it would serve to help others out.
Hi c2cthomas
How did you get on with the Karlson K-tube ?
Did you try it with the B+C compression driver ?
Cheers
Simon
Oh, I don't buy 6th order or 8th order or tapped horn theories tell the whole story.
This system is a synergy of too darn many things that defy such simple equations.
Maybe if someone wants to run CFD over the entire enclosure into a half space,
that sort of math might mean something.
I more than half suspect this thing is shaped to throw a vortex that propagates
and disperses somewhat different than the usual rule. Hardly the only weird trick
being simultaneously exploited to advantage...
Hi kenpeter
Thanks for your exellent drawings in the other thread.
Are you a K15 user by any chance ?
I have now seen fig.8 as well as fig.6... Mmmm...?
I have been pening a couple of Karlson variations myself.
I have now downloaded the 3 main Karlson patents, but have not had time to read them yet.
One interesting thing that I realised in drawing the Ultra Fidelity Enclosure to scale was, the front radiation obviously totaly misses the floor, I presume avoiding the annoying first floor reflection of all vertical baffle speakers.
When drawing the K15, I drew the driver first and then the box around it.
In doing so I couldn't help playing with the idea of a diagonal bottom rear chamber with a 2nd internal reflector inside.
I am continueing to draw out a few variations.
One of them became a kind of isobarik, double-ported cab. with 2 sets of wings, inspired by the Metro PA design.
I'm sure reading the patents will raise some more questions.
Cheers
Simon
