Hi guys,
I just browsed Fostex Japan's official web and found their product catalog by accident. Just go to page 4 of the PDF and you will see the new drivers. The 3" and 4" looks pretty promising to me, but I'm not so sure about running the 4 1/2" and larger without filters as anything above 3kHz starts to look uneven, especially the off axis. The 8" may be a nice wide-band woofer though, but definitely not a full range driver. IMO A simple inductor and capacitor crossover at 3kHz will be great for the 8" with SEAS Prestige 27TDFC as the tweeter.
Here's the link to the PDF: http://www.fostex.jp/user_file/fostex-sh/etc/SpeakerComponent2010_11.pdf
Boris
Boris
By the way, the cone will be made of two layers, one being long fiber wood pulp paper composite and another layer will be made of (charcoal?!). It will be better in bass than FE83En and FF85K, and at the same time allows lower tuning frequency and smaller cabinet volume. Seems nice, except the efficiency is unprecedentedly low for a Fostex driver.
I think the new lineup looks really good! We have our low and mid Qts options... whizzer and whizzerless... the curve of the 166en looks good to me. No one said it has to be flat to sound good. Some of the drivers have spikes that will give them a personality but i'm sure they will find their fans. The 165 seems perfect to mate with a helper tweeter. I like what they are presenting us with.
Zilla
Zilla
Godzilla,
You are right, sometimes coloration allows different "personality", and most full range drivers are not about being mechanically robust anyway, especially the Fostex ones, which still rely on decades old technologies.
Paper Cone? Checked. Overhung ferrite motor? Checked. Stamped steel frame? Checked. Cloth surround? Checked.
Zilla
I'm with ya on the above!
Nice lineup!
IG
it's almost like they were reading our minds (or the forums 😀)
a few thoughts
Kinda hard to tell from the resolution available on the 20 page PDF whether the UDR surround has been retained on the FF85KW (or expanded to other models), but it's heartening to know this driver will still be available, and the new FF105KW could well be a very interesting piece indeed.
Now, if anyone can translate the table posted above, or has access to full T/S parameters for the new units , the intrepid modelers can start (re)engineering enclosure designs. 🙄
As for the apparent reduction in sensitivity of 2.5dB between the old and new FF85K(W) and the in said table, it could well be a combination of more accurate measures than before, and some engineering changes in the motor/suspension components - note the 10Hz lower Fs.
Lastly (for now) - what will be most interesting will the be actual delivery dates and stocking levels of these new models. Remember how long it took for the recently revised FE -En series to reach all markets and stocks of previous and discontinued models to deplete?
a few thoughts
Judging from the Qo figures, the Qt will be in the ballpark of the defunct FExx7E series units.
FR graphs look to be relatively unsmoothed compared to a lot of published figures, so I doubt they're better or worse than the majority of such drivers out there. I suspect the UDR surround is AWOL though; only the FF85K of the previous range had it.
F120A and FX120 seem pretty linear to me.
FF165 can be handled with very simple and slight correction for rising response and can be combined with a high range...
F200 looks pretty good too.
And the most other have pretty comfortable dip in the response around 500 hz... 😉 - that combined with the front baffle step can lead to absolutely linear response.
Indeed the new Fostex FF lineup is good news.
Could this be "The Return of the Fonken" written by planet10 ?
Kind regards,
Yves
Kind regards,
Yves
to clarify, the entire pleated cone Sigma series had it as well - AFAIK, the 85K was the only "conventional" cone model with the UDR
Zooming in on the pics, things i was hoping not to see: no UDR, dustcaps are shallow & not directly connected to voice coil, and the surround looks to be convex instead of concave as on the previous generation & the FEs.
It will be interesting.
dave
dave
dave
sharper eyes than I - by the time they were zoomed to a visible size, I couldn't make out those details.
maybe someone has an inside contact to answer some of these questions? 🙄
Kind regards,
Yves
time will tell
It will certainly be revisted.
It looks like the FF85 has lost those features that made it special, the original's torch may have to pass to the new Alpair 6s.
And i do hope that they have figured out how to remove the annoying HF stuff in the aluminum dustcaps that had the FF125 and larger reminding me of what i didn't like about the Jordan JX92.
It does look like the FF85 will be more of a family with the others, instead of a special Sigma, hidden away somewhere unexpected.
dave
Hi guys,
Boris
Hi Boris,
Thanks for the heads up. Couple of interesting things: the alu cone 4" woofer, mag tweeter and, of course, their new craft book. The yellow egg speaker on the cover cracks me up(!).
Hi Boris,
I think perhaps that's an artistically fuzzied down-throat peak at the T500-A horn supertweeter.
The external configuration of designs on page 13 appear to be different from the previous factory recommended BLH, but I guess spell checker wouldn't detect that " Back Lorded Horn Speaker Box" is really something new.
Good observation Chris. Indeed the Japanese are not careful with their spelling. If you visit the official site, you'll be stunned by the amount of typos they have! They spelled "catalog" as "catarog" too. But as long as these drivers sound sweet, I don't really care. Also, there's no such problem in the international and American site, so I suspect the local Japanese are accustomed to those "alternative spelling".
UltraKaz, I found the metal 4" woofer interesting too, and they've been available for a while, mainly in their GX100. It looks really lovely.
Are you talking about the egg speaker in the "Craft Handbook" Cover? I think it's good to have it for Easter. 🙂
Dave, I've got some bad news (and possibly good news) for you.
The FF85WK will definitely not receive a UDR foam suspension for sure, but Fostex will make a special suspension for it, definitely not the cloth surround.
do you know if they're inverted/concave like the old and remaining FE series, or convex as per the F120A / FX120?
- Full Range
- New Fostex Range Scheduled to be Released in Jan '11
