Dammit, I lost a considerable amount of work in one of those excised posts. And a particularly funny remark.
So, a.wayne, SandyK, TerryO,
What about the evidence? The longer you carry on without producing any, the more it looks like you can't produce any. You all claim to believe this stuff about ripping to SS producing identical files that sound different. But you can't demonstrate it. How long do you think you can carry on and expect to be believed? Realistically?
I tried it. Nonsensical though I think it is.
I took the 4G SD card out of my Canon G9 and put it in the card reader, put an immaculate (it belongs to my wife) copy of The Beatles' Abbey Road in the Sony DVD writer (which is the best optical drive in this machine) and ripped a lossless .wav, first to the SD card, then to an 8G USB stick and then to the 250G WD hard drive. I then did an MD5 checksum on all 3 files using WinMD5Free with the following result: 4614643b634199ba5330ea789f9fa14d The result was identical for all 3 files. The track was 'She's so Heavy'
I then listened to all 4 files including the CD.
The files were played on this computer without removing the SS cards from the card reader or USB port. I listened to the files using the M-Audio PCI Audiophile 2496 installed in this machine through a Behringer Xenyx 802 Mixer as headphone amplifier with final output through a pair of Shure E2C in-ear phones. The OS was WinXP. The player was Foobar with ASIO.
I couldn't hear any differences between the files.
You may carry on believing, but how long do you think you can carry on, without any evidence, and expect to be given a tolerant hearing? We're not talking about a matter of religious conviction here, this is something that you could end all argument about, by simply partaking in a test that satisfies us all. If your belief is based on fact, you have nothing to lose, and everything to gain.
I'm keeping my part of the bargain, I listened. When are you going to ante up?
w
So if Waki don't hear it , it doesn't exist ................🙄
The Problem here Waki, is that you have no auditory experience when it comes to evaluating audio systems or sound IMO...Your past challenge speaks for itself, now you are demanding immediate discovery
My stance hasn't changed, Not all burned disc sound the same and if you have been following along you would have known that.
So did all 4 disc sound the same ...... 🙄
Well obviously it doesn't exist for waki.😀 But I think the point here is for those who do hear it - describe it in more detail so that others can repeat the experiment if they so choose. Its really not helpful in terms of progressing our understanding to say 'I burned Y disks and heard differences'. What we need is the details of the systems and conditions and content under which you heard differences - that's why waki's example is a good one (irrespective of his results), he described his methodology in a lot of detail. Kudos for that🙂
And then there is the Foobar ABX thing. It should not be hard to do.
So did you at least verify that the burned discs had no errors? You've never said.My stance hasn't changed, Not all burned disc sound the same and if you have been following along you would have known that.
And not just no errors in the drive that burned them, but no errors on the playback device.And then there is the Foobar ABX thing. It should not be hard to do.
Well you know the software being used and it is all self verification. I'm incorporating others you have suggested and will burn 1 disc from each software and then compare.
I do intend to,
1. Recurit 3 others ...
2. Use 2 different audio systems and along with my Sennhieser headphones..
3. Details of the electronics involved will be disclosed along with the Music track being selected which will be checked for clipping .
4. Intent will be to determine if A. anyone can hear differences between the reference disc and the burned copies B. then their subjective reasoning, likes dislikes etc ..
5. This will not happen until next week , i do hope Waki can hang on ............
This is my intent ....... 😎
No, it is NOT - as far as I can tell. That was my point. But you can check it after the fact with other software. (You may have to re-rip)
Glad to hear that you will run the tests. I certainly suggest the Foobar ABX plugin, as it will lend great credence to you tests.
Rock on Wayne! 😀
Some people have reported that dbpoweramp rips sound a little louder
Is it completely out of the question that the 'poweramp' bit has had some subliminal effect on loudness?
Wtg wayne😎
analog_sa said:Is it completely out of the question that the 'poweramp' bit has had some subliminal effect on loudness?
Entirely plausible hypothesis. How to test it - get someone to develop 'dBresistivedivider' and run sighted listening? 🙂
A question for the more... outre fellows. If I rip a CD to a thumb drive and rip the same CD to a hard drive, then burn CDs from each of those, will the CDs sound different from one another? Will they sound different than the original CD?
No it won't.
What will lend credibility to the tests is a published methodology that incontrovertably prevents pollution of the results by participants having knowledge of which item is being tested.
The equipment or software employed is irrelevant. To suggest that the use of a particular piece of software 'lends credence' is naiive at best and mischevous at worst.
This is why I don't stop participating in the thread, pano. I went through this in the RF Attenuators thread. I can't trust you guys to keep your eye on the ball.
w
Gee thanks Waki. That was very helpful - not.
A step away from uncontrolled test to at least some blind ABX procedure is not going in the right direction?
No it won't.
w
Did you burn 4 different cd's and compare them as discussed.... can't keep your eye on the ball ?
Funny you are willing to discount the value of what we are attempting with, well naught. Do you even listen to music Waki? I noticed you used your wife's CD , do you have any for yourself. No wonder you are quick to denounce others, who actually listen and have to Live with this stuff..
An assumption made about something before having adequate knowledge to determine the results sounds like "Prejudice" to me ... 🙄
Now toddle off and Burn those 4 disc ....
aw, can you look at my previous question?
Not sure Sy,
We have only ripped from HDD. Might give the jump Drive a try if we have the time. Since most burn from HDD then this is were we are concentrating our efforts.
When ripped from HDD we sometimes hear a difference from the original. It happens enuff , so much so that if the recording is something you treasure , we usually buy direct from the source instead of ripping, say from reference recording, , Telarc et al ..
regards,
regards,
OK, thanks; so let me ask it this way- if I take a file from an HDD, burn it on a CD, then rip it back to the HDD, will the two (i.e., the original file on the HDD and the ripped to CD/ripped back to HDD file) sound different?
I dont know, my only experience with this is the burned disc from the Hdd sounds different from the original.
And you're still happy to repeatedly say this in open forum with no supporting evidence?I dont know, my only experience with this is the burned disc from the Hdd sounds different from the original.
I'll say it, too....happily😀
Best Regards,
TerryO
And the difference remains or goes away when the file on the burned disk is copied back to HDD?
And you'd still be happy to repeatedly say it in this thread despite the fact that it bears no relevance to the topic of this thread?I'll say it, too....happily😀
The signal to noise ratio in this thread is nearly as bad as the one it was split from a few days ago due to signal to noise ratio problems.
- Digital Source
- HDD vs Flash Drive - Ripping and Playback (Split)
