what if sub-woofer in a folded horn?
What do mean?...a subwoofer driver? in a folded horn box?
magandang araw,
jojo
jh186
do crown have their showroom in quiapo/raon?
how much sir is jh186?Yap...Why? oh! why?
1. JH186 is CHEAP!
2. JH186 has approx. 6" VC with a fairly strong paper cones.
3. JH186 is locally available...so replacement parts is readily available...I Guest?
4. the "Instrumental" print is somewhat confusing to me too...in the old days when see those prints it is specifically used for Guitars and KB amps...but it doesn't matter anyway driver are classified by way they are built...check they T/S if they are suitable for your specific needs.
5. Time to go...
Magandang araw,
jojo
RHODRICH/DJ JOJO MD
different crown in same box(wsx)
seem wsx is speaker friendly, easy to tune performance satisfaction guaranteed,
two masters @ 150hz?
engel dela pena,
both speakers are 5 inch voice coil, if i know before that there is a jh186 speaker i would buy that. so i decided crown pro-1815. the sound is not bad i like the way it sounded. then i also try before p-audio 650 el. the box will rattles and not stiff but for the 1815 stiff sounding. they give me before the price for 1815 10k but i buy more so they give me 8300 pesos each. i dont know about the jh-186 price. the jh-181 is about 5500pesos cebu area. i did not try yet testing 16 wsx box / i only try 4box but sounded good. sir jojo have more experiece about this box.
@ audiomachine
Sr. do you have schematic of CA6 of crell or sound stardard? i have one here needs to be repair. new circuit version.. thank you.. pls. send me garlic_169@yahoo.com.
group buy announcement,
http://www.diyaudio.com/forums/solid-state/177120-professional-class-h-amplifier-2kw.html
engel,
im also intersted about the pcb but maybe we have problem after about the parts if all available to us or we can find parts in our country?
engel,
rhodrich,
workhorse is not that bad,he will help us,besides he uses 5200/1943 pair and ir2117 driver,hard to find parts will be FARNELL'S job
el-36 plan link
Cerwin Vega
sir i'm after the top view, i want to see the displacement area. . . thanks
hi engel dela pena
greetings VTL5C4 VERY HARD TO GET in my city supplier has
only 5 pieces very costly 55o rupees NSL32 ONLY 170 rupees MUST KNOW
PART LIST OF SEMICONDUCTORS SO WE CAN CHECK IF AVAILABLE THEN ORDER
PCB
THANKING YOU
ANDREW LEBON
PCB
THANKING YOU
ANDREW LEBON
good day! is anyone of you here got a schematic design for konzert K6 or K8 power amp? or any power amp schematic design same as k6/k8 wattage...
ty in advance..
ty in advance..
l-36
SL36
this is all i got sirsir i'm after the top view, i want to see the displacement area. . . thanks
SL36
@ jojo
thanks sir jojo, i think i have to remodel the speaker displacement of my EL-36. it is widely open as is the circle. cause it doesn't throw the bass as i was expected. the box is already jumping but the sounds is just around of it. and i don't feel the bass punching especially in the front. thanks again.
i'm running a live band services but i'm too disappointed to my highs the way it sounds especially from the vocals. sometimes "natatabunan", sometimes irritating to ear. . . i've been trying to make that crispy, loud non-irritating highs but still. . . do i have a wrong setting or do i need to add something to my system? i have the mixer to equalizer to crossover to amplifier. i have the compressor/limiter for the insert of the vocals. PLEASE HELP.
nothing wrong with your equipment, level setting of each instrument on your mixer channels is probably your problem, observe good miking techniques over the instruments to increase your gain-before-feedback, good gain structuring of the equipment, quality mics or get a better FOH tech just kidding
- Live Sound
- PA Systems
- Konzert Amp & Speakers Website
