This is not a high spl subwoofer, it's purpose is to give my alpair7 tl's support from 30-60hz.
Using two 4 inch drivers (W4-792sj) seems a bit weak in subwoofer terms and when simulating in hornresp they x-max-out at 7-8W in this setup.
The reason I picked 4-inch woofers is to keep the total hight of the box below 14 cm which happens to be the space available under my sofa 🙂
Well plugged in and running, crossed at 60 hz 24 oct/db, I'm more than surprised over the efficiency of a tapped horn. I would guess that the cone displacement is just over 1mm at max level of the alpairs (subwoofer level tuned at my flavor of course) and in my way of listening to music thats l o u d.
Just wanted to share this since I'm so happy with it!
Regards H@kan
Regards H@kan
Looks neat!
I am interested in that Hypex amp due to it being relatively cheap.
How do you think it fair in a TH?
Did you defeat that boost at 25Hz or did you do any other modifications to make it suitable for a tapped horn?
IIRC the built in LP did get a lot shallower when crossed below it's max setting.
Can't remember exactly as my main PC died where all links and docs are.
The amp is straight out of the box. No mods.
The spec says there is a bass boost at 25 hz but only +2db so I decided to not take that in consideration. At some resellers it's claimed +6db at 25 hz but the manual states 2 db and I think thats the correct value. I see now that LP-filter is 18 db/oct but It's probably flatter.
It would have been nice to disable the bass boost and perhaps kick in the subsonic-filter at 30 hz instead of 20. I have not really checked out the amp-module but there is alot of smd components on it and thats where I'm usually give up when it comes to electronics 🙂
Regards H@kan
Regards H@kan
Funny, I was interested in trying to use two Silverflute 5.5" drivers for this same purpose but for the CHR-70's in my office. I was even contemplating the Volvotreter 30hz tapped horn using the Tang-Band 6.5". Hows the sound? Output, Linearity, definition ect.
When crossed low at 55-60hz I really like whats coming out of it. Sounds distinct and solid. If I try to crossover it any higher it sounds hollow and even with blindfold there would be no problem to point out it's exact position.
This is really an one octave sub.
I dont know about the output power but as mentioned earlier it has no problem to cope up to the levels the alpair does.
Regards H@kan
..This is really an one octave sub..
My first impression too..
..If I try to crossover it any higher it sounds hollow and even with blindfold there would be no problem to point out it's exact position..
You might find the reason here:See the picture.
Did you use measured TS in your simulations?
b 🙂
If possible, try LIGHTLY stuffing the first 1/3 to 1/2 of the horn, starting from the throat, to see if that will make a difference to that "hollow" sound. See The Subwoofer DIY Page v1.1 - Projects : A "Proof of Concept" tapped pipe** - introduction - I was able to substantially change the output at higher frequencies (and even eliminate a deep notch) by stuffing.
b 🙂
The limited bandwidth is not a problem since it will just fill up the interval between 30-50 (or maybe 60) hz. The output is more than enough as well.
Whats worse is if I have used wrong ts parameters. Where did you find yours? I have used this data sheet:
Europe Audio
From what I can see bl and mmd differs from your values.
That could be useful info if I, at some point, need it to go higher i frequency.
Inserting the stuffing would be a problem thou since the box is glued.
Regards H@kan
..Whats worse is if I have used wrong ts parameters. Where did you find yours? I have used this data sheet:
Europe Audio..
So did I ,
..From what I can see bl and mmd differs from your values..
I also consistency checked the data: Double click Sd in HR and you will find out why I used different parameters.
b
So did I ,
b
Okay I see now that you have entered Fs and Qes in addition of a assumed correct Cms and Re to calculate BL. Is that preferable over entering manufacturing sheet values direct into the BL field?
Regards H@kan
Hi Håkan,
Yes,The consequences will appear immediately after entering all relevant data when pressing Sd for to finally check the main fundamental parameters: fs,Vas,Qts(Qes,Qms)
b 🙂
b 🙂
Hi Håkan,
b 🙂
Okay! I will try that for my next build.
I will measure this one soon.
I'll be back with the results.
Regards H@kan
I noticed this yesterday, but didn't have time till now to post about it. As soon as I saw the 0.17 Qes/0.16 Qts I knew there was almost positively something wrong with either the published specs or his, if measured.
Using the EZH spreadsheet and the more likely specs (though best as always to use measured), I get a near perfect match to my calculations once S1 is increased, so maybe a good enough alignment if others want to try it or one can see if there's any benefit to a four section:
GM
Last night I did a quick measurement. Mic was flush the terminus (or mouth the correct term?). It seems like Bjorno's first sim, with my faulty ts parametrs, is pretty much what comes out of the horn. One have to take the measurement with a pinch of salt, of course, but the similarities to the sim is quite significant. Filter on amp is set on 150hz.
Thanks for pointing this out! My next build had likely suffered from faulty ts parameters if this hadn't come to my knowledge.
I will definitely look into measure the ts parameters.
Regards H@kan
GM
Regards H@kan
Hello,
sorry to be a bit late,
i wanna share my experience with slim TH, i prefer a double horn construction,
with the movic 4" 16 Ohm, with measurements:
subfanfare
subfanfare
- Subwoofers
- Ultraslim tapped horn
