Buffalo II
I asked how much gain, not output amplitude.
What is the amplitude at the output of the DAC chip?
Then you are ignorant of the question you should be asking. 😉
This is current to voltage conversion, not voltage amplification. 🙂
Now if you are interested on how much current gets converted into how much voltage you can find that answer in two very convenient places. The above post, and the manuals/schematics. 😎
So, what is the DAC's output current?
What is the DAC's output amplitude when operating in voltage mode?
Volumite firmware question
Volumite Firmware for Buffalo-II Stereo/Buffalo-II Dual-Mono/Buffalo32S
I currently have the B32S w/volumite. My assumption is that the programming
(firmware) for the B32S is the same for the B32II. My firmware is from my B32S purchase back in May of 2009.
I ask because I will be switching to the B32II.
