Mic, Line, EQ... Preamps
APEX do you have a 2 band tone control made with transistors instead of opamps?
you posted a tone control circuit a long time ago with a tl074 quad operational amplifier).its working good.i attach a photo of it. do you have the same circuit with pcb but with 2 opamps? i have 2 opa2134 (dual operational amplifiers) and i want to use them.
I must check in my old projects, and I will share if I find some interesting schematics.
Gradiente P-II
Excuse me, let me share schematics for the one I have at home.
Max.
Mute
Are you sure those 1N4007 are connected to the right place?
Shouldn't they be attached BEFORE the bridge?
Sorry, I didn't test this circuit, but I am trying to understand its behavior.
Thanks.
Max.
hi apexaudio
greetings can you tell which amplifier to use for active croOssover
1TREBLE 8 TO 18KHZ
2 MID 750 TO 8KHZ
3 LOW FREQENCY 150 TO 750 HZ
4 SUB FRE 40 TO 150 KHZ 50 HZ BOOST 24DB SUB GAIN CONTROL 12 DB
5 FULL RANGE OUT ALSO
only want amplifier 100 watts for hf P AUDIO COMPRESSION UNIT 100 WATTS
have finished crossover will test it today
thanking you
andrew lebon
