Papa, Watt's next?
Are there any good FM tuner designs on diyaudio (or anywhere else) that you know of.
Single analog challenge i can think of with tuners are the output stages behind the stereo filter
(exchanging opamps in this here forum means a swap to Papa's favorite crud :clown: )
Couple of years ago Mark Gulbrandsen and me shared a fantasy of cloning a MacIntosh, with the looks of a (Day) Sequerra, including the CRT spectrum display, and the build quality of old series Tek.
(i've had a hard-on for the Sequerra Model 1 (FM reference) since the late '70s, early '80s, just checked, still do)
Service manuals and schematics of thoroughbred tuners such as the MR78 or Dick Sequerra's Model-1 can be freebee downloaded from the web.
(or buy an old Restek Metric/FM3003 tuner for a rehack)
If you are prepared to use transformer at all, you might as well use a tranformer preamp, either totally passive (if your source can drive it), or one of Susan Parker's.
Attached one from the old Blowtorch thread -- passive Tx + source follower buffer.
Patrick
Efficiency, low to mid 90's, 8 ohms.
$125 sometime around the end of the year.
Here's are curves of mine in an OB as seen at BAF 10
days ago.
