Hey Russ, just wondering how you going with XMOS module?
I am working on it right now.
I am implementing an XMOS based solution. Stay tuned.
I am guessing first prototypes are 6-8 weeks off. Just depends on other time demands.
Cheers!
Russ
Funny you should ask. very well actually.
Yesterday I was hacking up a prototype based on some stuff XMOS sent me to play with. I am able to get it working, but It still needs some attention.
I am going to be focusing on that module very hard over the next few weeks.
Cheers!
Russ
Cheers!
Russ
You writing your own drivers? I looked at that while ago with the XMOS, but figured it would swallow a big chunk of my life, so bought a Hiface instead!
No, not writing my own. Using the stock drivers on my macbook pro right now.
I have also used the driver XMOS provides for windows. Both work just fine.
To get higher than 192khz via USB audio I will likely need to do some customization of the driver.
For now I have played signals up to 384khz directly from USB storage. But, I have not perfected this yet.
My hope is to be able to make the board work both as a host controller with USB storage and as a USB audio device. We shall see...
I guess the USB/SPDIF(I2S?) board might be even a bigger success than the Buffalo II, so you'd better be prepared for that, I hope I won't need to stay awake all night again.
Please Russ, show it the kids...
Who said anything about S/PDIF? I thought the module was for the Buffalo DAC.
Well, I hope it's an I2S interface first and foremost. I wish the industry would retire S/PDIF.
There is no compromise on the module to support both. Just use the one that suits your application best.
Well, no one ever said anything about it actually, that's why I was hoping Russ would show a picture to us (referred to as "the kids") so we get an idea on how big it is as most of the people with Buffalo IIs have already assembled their boards and will have to rearrange them.
How could we combine this board with more traditional inputs like the Mux?
Should an Otto be used to switch between a Mux and the USB input? If so, can we expect the AC2 in the same timeframe to provide an easy switching capability? Or will a new module provide I2S passthrough/multiple SPDIF ports?
Those are two separate concerns. The USB module is simply that. USB in -> SPDIF/PCM out.
The OTTO will work to switch two I2S sources.
You could also use the SPDIF from the USB module into the MUX.
There is something else I am working on too, but it is too early to talk about it.
Cheers!
Russ
Cheers!
Russ
Ok, I was thinking about getting something like an Arduino/AC2 to connect a display, set the Mux & Otto to the right settings using fi. a five position switch and control volume with a rotary control and/or IR input. And perhaps even create a 12V trigger for my amp.The OTTO will work, and there is something else I am working on too, but it is too early to talk about it.
That would really finish my DAC
- More Vendors...
- Twisted Pear
- TPA - USB Transport
