GB for DC coupled B1 buffer with shunt PSUs
Nikon1975 paid up. Thanks.
More than 1/2 signed up have paid 🙂
I've been asked about the build guide. If someone has it and can post it again I would appreciate it. I will do my best to update it, possibly but in blog format. Probably no step by step pic's though.
I had asked for this one a long ago but I hope this time we can catch up just before release. The Oenboek T mod for a grounding to earth, relay contact eliminating, double layer with top pads and plated holes facelift on Mez. Jumpers are err... jumped too. 😀
It's been asked, this will be the production board for the Mesmerize. A different 2L weaked version with T mod, 2oz copper. It will cost more, so Salas and I won't celebrate by buying a Lotus Elise, more of a used Citron instead.😛
The only difference here will be that this version won't be prototyped. Minor variations should not require it.
If you want to hot rod it, TO-220's will fit with little effort, and you can use a small cap for Vref bypass, and use panasonic 10R resistor should fit (Well that's only 3W, I use two). You'll just have to stack or offboard some other big cap's if you prefer, Like TSHA 47000uf.
