Peerless 830586 8" SLS Shielded Woofer
Was: $35.00 EA
Save 31%
Special Price: $24.00 EA (1-3)
$21.68 EA (4+)
Sku 299-246: In Stock
Perfect woofer for equalized sealed box designs. Stamped steel frame with generous ventilation and minimal airflow restriction. 1-1/2" two-layer copper voice coil with 1" winding. Shielded magnet, 4 ohm impedance. Buyout, limited quantities. Specifications: *Power handling: 125 watts RMS/250 watts max *VCdia: 1-1/2" *Le: 0.97 mH *Impedance: 4 ohms *Re: 3.4 ohms *Frequency response: 45-2,000 Hz *Fs: 45 Hz *SPL: 85 dB 1W/1m *Vas: 0.72 cu. ft. *Qms: 6.19 *Qes: 0.96 *Qts: 0.83 *Xmax: 8 mm *Dimensions: A: 8-3/16", B: 7", C: 4-1/4".
Premium sculpted stamped steel chassis
Vented pole piece and under-spider venting
Treated long-fiber paper cone with rubber edge
Oversized felt dust cap
2-layer front gasket
Bumped backplate permits maximum linear excursion
Magnetically shielded
Was: $35.00 EA
Save 31%
$21.68 EA (4+)
I have a pair sitting in my office ready to be tested. As supplied, the Qes is too high, but I think if I knock off the bucking magnet, things may improve....
Was: $35.00 EA
Save 31%
$21.68 EA (4+)
FYI, A TL simulation:
b🙂
In theory, Qes will increase...........
GM
I thought the bucking magnet *decreased* the BL slightly, and that you get in increase in the field when you dispense with it. But certainly not by enough to make a speaker more horn-friendly....
As supplied, the Qes is too high....
Maybe, maybe not, only one way to know for sure........
GM
IME, adding a magnet either did nothing or slightly lowered Qes, ergo taking it off may increase it, but I agree that it probably won't be enough to audibly affect the design. That said, there was a small Audax that could be had either way and the shielding dropped it almost 20% IIRC, but I've never seen anywhere this much on the 8"-up drivers I've messed with and finally settled for using cold rolled steel (CRS) sheet in the cab to shield larger, more powerful drivers.
GM
Well, we'll find out soon enough. I will measure a driver, then knock off the bucking magnet and remeasure. If they're not useful without the magnet, I'll send them out to live on the shelf of useless woofers I have out in the shop....
Might be a few more days though - I'm plenty busy with other projects.
GM
Oh - I agree that it was worth a look - that is why I bought them.
This driver is not bad by any stretch, it just has its limitations.
I thought I was the only one with a speaker addiction....
My name is littlemike, and it's been 3 days since my last speaker purchase....
HI MIKE !!
HI MIKE !!
Hi Jim.
It hasn't been three days..... 😀
There are more boxes coming too - but that is another project.
PA-style tapped horn bass on the cheap - if it all works out. In simulation-land with fairy-tale parameters, I get >100 dB with a watt from 30 Hz to >120 Hz from a pair of $20 12" drivers, and the model says the drivers reach excursion limits at just about the same time as thermal limits.
Downsides? It is a BIG enclosure for a pair of 12s, and it all hinges on manufacturer parameters currently - I'll get actual driver measurements soon (probably Tuesday). I'll measure the M&K's at the same time.
GM
And - theory would be correct. Measurements attached.
So - in an nutshell, leave the magnets on...
Turns out that the specs were reasonably close to the listed ones. The driver is a Parts Express buyout, item number 299-246, which is a Miller & Kreisel badged Peerless 830586 8" SLS Shielded Woofer.
They'll work well enough in a tapped horn - with or without the magnet. They don't take a lot of power before excursion gets silly when asked to play low, and the cabinet gets pretty big. I've got other stuff to do, so I will not be playing with them any time soon.
I wonder how these compare to the other MCM 8" that everybody seem to use as a cheap option for building front loaded and tapped horns - as far as being used in a horn is concerned. I heard these SLSs are great in car doors though, if you can fit one...
Completely different drivers - the MCM has more motor and a much lower Fs than the SLS. The SLS is a great IB driver, and will likely wind up in the doors of my truck
Yeah I hear you, the MCM does have much more motor and xmax, but thats the thing, I always thought high FS drivers are better suited for horn loading, yet everybody on a budget seems to base their bass horns on the MCM. I think I have read somewhere that FS should be about a little less than double the freq you want the horn to be tuned at?
Anyway, right now the dayton 8" on half price looks much more interesting to play with :
Dayton SD215-88 8" Shielded DVC Subwoofer | Parts-Express.com
i cant believe you recommenced that dayton driver... seriously
Look at the frame on that driver - those will be really hard to front-mount.
May or may not be an issue, but worth knowing ahead of time.
@90210
To each their own, not everyone needs 140 dB from their subs, and sometimes a $15 driver is just right for the application. It is a lot easier to learn and experiment when the cost of the driver leaves a bit of change from a $20.
your not alone,
me and loud speakers have a serious obscene relationship, and my stuff is overwelming my garage, and house. but my small home theater is pretty bad ***. And i dont even have to use the dual 18 cabs in the garage , lol. peace. just too much fun. gotta strap the house to the foundation soon.
- Subwoofers
- would these be ok in a tapped horn or folded, any ideas, i got two the price is good
