The Very Best Amplifier I Have Ever Heard!!!!
The topology is not unusual.
There are amplifiers which are almost like that.
There are 3 things I notice are a bit special.
- The use of a DUAL JFET in input.
- The triple paralleled 2SK134/2SJ49 lateral MOSFETs in output.
- The separate regulated input/VAS supply.
The last point, the separate regulated supply for Input/VAS
is something I have recommended many times.
Because it is just crazy to supply the sensitive first stages
from a heavy current un-clean output supply.
Still stupid designers, over and over, keep on putting all of one power amplifier
to use one and same suppply!
This shows a fundamental lack of understanding what happens
when we run an audio amplifier feeding loudspeakers.
PCB layout today in.....few hours
Nice schematic , and my contribution to diyaudio forum 🙂
Regards Alex.
  • MOSFET PDF.pdf
    MOSFET PDF.pdf
Reactions: Silvio Novais
Power rating is approximately 250 watts (2-8 ohms).
Frequency bandwidth is +/- 3dB from 0Hz-1MHz.
This is a wide bandwidth amplifier, sounds incredible. I understand that the metal can military dual jfets 2N5565's are obsolete and dificult to find, but they are significantly superior to 2SK170's.
Same goes for the output MOSFETS. But I agree that this is a logical upgrade, since all the parts are readily available.
The gate resistor value seems quite low (100R). On lateral mosfet amplifiers that I have rebuilt recently I have used 1K for the N channel and 680R for the P channel. The 2 differing resistances helping to compensate for the different gate capacitance values.
I know that the old Hitachi mosfets are more forgiving than the modern equivalents that most of us have to use.
The driver and output stage are very similar to my modified Rauch DVT 50S, which is what I use in my current home system.😎
Doug,
I have never gotten myself involved in etching my own stuff. If the post by Alexmm is to scale, the dimensions are printed on the board, it should not be to terrible hard to transfer to the laser printer and make.
Does anyone know if this a commercially manufactured amp. Where did this design come from? I have been looking for something greater than 100 watts with jfets in the frontend.
Now how hard is it going to be to source most of the specified components. Most of the good Japanese transistors are scarce and expensive here in the U.S.
Tad
