hi to all..... can anybody recognize this amp design? i saw this from i think a russian website, i could not understand the language, it looks interesting and uses just ordinary parts... thanks
Hi C3PO...
Thank you for share schematic.
hi teslar, if you have any information at this amp design just let me know... thanks
class g amp
eesbiboi, if im not mistaken i found this design at 320volt.com, im not sure, because the article is russian, if you are interested building this amp let me know... thanks
sir can u post a link to where u found that amp design???...
tnx
regards
ees
500 watt bjt anfi devresi mjl1302 mjl3281 - Elektronik Devreler Projeler
It's a turkish site that also several schematics like the Krell KSA Mk2 from this forum.
hi c3p0..from what place in angeles you are located?
sir junm, sa pandan ako near marisol, but im working in dubai now... thanks for the link, i want to try that amp, i have stocks of transistors here (cheap price electronics keni😀)
Mosfetli quality output amplifier circuit 3 times the output power and the drive times used irfp9240 irfp240 and two op amp circuit is used to drive the circuit in 4558 in times of peace movements do not need to set for
Supply voltage is + - 60 volts and + - 1130 rpm position volt output is also the Source schema and pcb files: 500W-mosfet-amplifier-circuit-irfp240-irfp9240-power-anfisi.rar
CAUTION Be careful when working with high voltage capacitor circuit to make sure the connection / - connect the opposite polarity high voltage circuits large explosions could be insured before you turn the power line, use protective glasses
Author: gevve Date: 7/03/2010 Tags: amplifier circuits, power 😀
coolet.. thanks for the info, is that schematic correctly drawn? theres a low value resistor 3.3 ohm 1watt connected from speaker output directly to signal ground ( at the left corner of the schematic) maybe it will blow when driven at high power...thanks
can you attach the pcb layout and parts? i can't open it over here. we'll confirm it from that pcb layout.
500 w amp pcb
coolet, theres no wiring layout between the output module and drive board... thanks
500 w amp pcb
coolet, thanks for the correction. 😎
in the schematic the NFB was mistakenly connected to SGND. see attach schematic.
coolet, it seems the amp has no NFB going to the op amp.
yes no NFB going to the IC. Is there no Layout for the PSU? it seems other parts is in the PSU like the D2012.
500 w amp pcb
coolet, theres no psu layout, from the output stage picture you can see an extra transistor bolted from the heatsink, maybe its the d2012.. hows the stability of this amp without feedback?, and no vbe bias circuit for bias adjustment and thermal compensensation. thanks
500 w amp
yes thats it. maybe the feedback resistor is missing in the schematic, there has to be NFB on this circuit somehow, thanks coolet
yes i think that is the one... thermal compensation configured as a diode.
- 500 watts Class g power amp
