Hello Everyone,
I put in my order for an Aikido 5687 board yesterday, now I'm trying to figure out IR remote control. I've got a two questions that I'd really appreciate a couple of pointers on.
These questions are based on two listing for IR volume control:
The first, is a motorized ALPs POT: 4 way Motorized Remote Control DIY Kit PCB w/parts/MV04 - eBay (item 230523481604 end time Oct-07-10 14:54:10 PDT)
The second is relay control descrite resister: Hi-End Volume Control DIY Kit,LED, Remote Control /V-03 - eBay (item 230523302177 end time Oct-07-10 06:14:55 PDT)
Now my questions:
1.) They both say that the power supply draws AC9-12V, 3Amp. Can this be true?? The largest 12V transformer that Mouser sells is just 24VA (e.g. 2 Amps): F218X Triad Magnetics Transformers
-- So, is the ebay specs wrong or is there somewhere to get such a large transformer?
2.) Which of these two IR volume controls are the best? I'd think the non-POT one would sound the best, but it would seem strange to not have a knob. Would there be a big difference in sound?
Thanks for your help!!
Best Regards,
Stan
Now my questions:
Best Regards,
Stan
Stanley: Both Mouser & Digikey have a few 12V transformers exceeding 3A/36VA, although there aren't many and they get expensive. You have to play with the search filters a bit.
Hopefully the mouser link below works.
Transformers
Here's a Hammond that's affordable and 30VA.......
186D12 Hammond Manufacturing Transformers
Transformers
12.6V transformers are a lot cheaper. Put a bridge rectifier in series and short the +/- terminals to drop the voltage by 1.2V.
Personally, I think very few things can go wrong with a motorized pot. The conductive plastic types from Alps are quite excellent.
The quality of the discrete resistor solution depends entirely on the PCB layout, resistor quality, relay quality. 1 dB steps is fine. In my opinion, the display board is *WAY* bigger than it needs to be. I'm not a fan of using 3/4" displays when the 8~10 mm (less than 1/2") is plenty big. Blue displays! Gimme a break. You'd have to wear sunglasses when viewing them. But each to his own I guess.
If you want a knob rather than push buttons, go with a pot...
~Tom
~Tom
Great guys, thanks so much! I must have been using the web interface wrong.
For the second question, which of the two types of volume control do you like:
-- Motorized ALPS POT?
-- Non motorized Relay control??
Best Regards,
Stan
Best Regards,
Stan
~Tom
Great Tom! Thanks for the advice!!
Best Regards,
Stan
My partner in Israel still have some kits he can sell. However, they are not remote controlled, but they have input switch as well. Can be controlled either by an ordinary pot (built-in A/D converter for this purpose), or by a switch (built-in diode matrix).
Here are files he sent me:
Index of /maat
Picture of PCB:
Knock to alexanderzas in Skype, say hello from me.
Index of /maat
Picture of PCB:
- Tubes / Valves
- Two questions on IR volume control
