First Project
What kind of sound levels can be expected from a speaker with a 70mm paper cone in spawn MBVR or Mar-Kel70 cabinet? Lets say in a 15' x 20' and smaller rooms (don't know which room they will end up in yet)
Well, i'd have to say just what Dave said: A lot more than you expect.
Since the EL70 appears to have a natural roll of below 100hz or something you can even play rock at very loud volumes with them and theres no problem with excursion or such. But there's not very much bass in the Mar-Kel cabinet. Mine aren't finished yet though, with dampening and such.
And this guy (my uncle) was lucky to survive an encounter with a moose. His car not so much.
dave
Wait till you are done. Lots of bass in my pair. Lots.Gotta get FM3 running and see how low.
dave
Yeah, maybe some more run-in time and proper dampening and sealing the top piece will do...
dave
Our Audi A6 S-line (it was a 2007 i think) looked pretty much the same. The roof was pushed back almost a meter. The car wasen't worth repairing, estimated costs was above 400.000 swedish crones (which is bloody much money!).
How did ur uncle do then?
Noble yes, but scary ! I had a bull moose swim across a lake that I was camping by (Algonquin Park, about half the size of Wales) and walk through our campsite in the middle of the night. These creatures are HUGE.
So why do you call yourself Scott 'Moose' ?
You have to meet one in real life to realise how huge they are.
And indeed, they are noble animals with some sort of "aura" around them i think.
One of my wife's friends was "stopped" by a couple moose blocking the road, on the way to work last year. Was driving a VW bug.
The moose walked up to the bug, walked around, giving it curious looks.
Then one of them decided it would be fun to turn it upside down w/ an antler,
and the two of them spent a good while spinning the upside-down beetle around, and batting it back and forth, like playing hockey...
then got bored & walked off...
the backed up traffic righted the bug (& strapped in, dazed, but otherwise ok driver...).
On the moose thing, I am surprised how fast they can run. Saw a moose running in a gully on the road side ahead, then it veered up the bank to the side of road and for a second we were side by side, we were travelling at about 100km/h he was running maybe at about 70km/h? Scary but cool.
Could this be a fair comparison between a Spawn BVR (ie. Derwent) and the Mar-Kel70?
Mar-Kel70: with its stiffer cabinet structure would have a cleaner/precise sound
BVR: Larger internal volume will have a bit deeper bass, perhaps more colouration from the cabinet.
In Derwent's simplest form that may be so, but it doesn't need to be.
The Spawn BVRs use the same style high aspect ratio ports as the miniOnken. In at least one case (Brynn), the Spawn is directly based on a miniOnken derivative (Classic GR Fonken). We have built both. With the same bracing structure, sand filled behind the deflector & doubled sides to allow for a bigger champher (and stiffer sides), out Brynn was no more colored but with bass that was a bit more effortless and had no need for stands. It still did not quite have the finese of the FonkenPrime, but that comes from a narrow baffle, and the BIG champher.(Derwent has the narrow baffle)
Derwent, with more volume will trade a bit of control at higher volumes for deeper bass (not having heard it, that is a hypothesis based on experience)
dave
Interesting comments Dave,
Would a cross holey brace similar to the Thirlmere (90 deg below the driver brace) be something that help the Derwent? If an additional brace is added would the volume need to be increased by the net area of the brace?
Adding sand to the bottom sounds like a neat idea, if anything it probably make the slender tower more stable.
I will be ordering the components to day and hopefully pick up the plywood tomorrow.
Looking forward to the build.
Rick
If you want to try out something simple,just to get an idea of what full range is all about,
you could go for a pair of Beymas 8ag/n on a bass reflex enclosure.
After finishing my "viech´s",I wanted something smaller and ended up with a pair of sweet sounding loudspeakers!
Believe me,they work really well and bass is surprisingly good!
