KSA50 AMP(New production Live in...)
your board has more parts add compare the pinkmouse pcb 😱
Abin you build ksa100 pcb too.
Which you think better ?
ksa100....
Here you go
I have all the gig devices.
All i still need is:
4 x 56k resistor
2 x 12V relay
4 x 27v 1W zener
4 x 470uF 63V
2 x 750 ohm resistor for relay
4 x 330pf capacitors
Before I can bolt it down onto a heatsink and power it up 🙂
Special for Johnm : I tried to pm you, but it's impossible.
In fact, I need your zip file for the CDM4 replacement/calibration.
Just let me know how I could get it...
Thanks a lot,
Tony.
Would have been better to put this into the Digital Source section, but yes I still have this zip file.
Give me an email address and I'll get that off to you.
Sorry for the thread-bust folks! (Perhaps this can be moved?)
- John
Hi gxcabin maybe you can create a seperate thread for the tube preamp stuff like under the tube part of the forum. And then we keep this thread for the ksa 50 board and it's assembly and tests.
I have no comment on random people chatting about zip files though.
