KSA50 AMP(New production Live in...)
Hi gxcabin
give us a bit more info on your design
what sizes in uF for the 4 capacitors?
voltage rails in volts?
what size toroidal
i am a bit worried about the two bridge rectifier sizes ,aren't they a tad small ?
Thank you for your question,
1, filter capacitor use BC of 6800UF/63V (6800UF * 4)and is compatible with all kinds of capacitors
2, the design supply voltage is AC32V (0-32V 0-32V) 1 channel
3, this design does not intend to use the toroidal transformer,Will use 1000 watts's EI type transformer,EI transformers with small filter capacitor combination, I think it is perfect.
4, rectifier bridge volume small, but each reached 35A, one PCB use two.
D35xb60 35a 1000v pfs
wow . I didn't know you got 35A in that package type.
I will probably run larger capacitance and the bridge rectifiers off board anyway.
I like big toroidal with big filter capacitance with this amount of current. I will probably use 800va with 60000uF or more per voltage rail for each channel. Personal preference 🙂
more questions:
1)Which devices do you tend to use for final stage? I see you made provision for 2 pairs on the pcb.
2)have you done some calculations on what bias current you are going to set up?
Sorry for all the questions. Just curious about your specific design.
I will have more questions 🙂
You're perfectly welcome to ask questions, the key is the level of my bad English, I do not know if many issues to answer in English, sorry!
Ring-type transformer and EI-type transformer is not the same, you can always go to test,Personal preference.EI-type transformer and the ring-type transformers, intermediate frequency, low frequency at which the former was better.
PCB version published by the last, what kind of device is very flexible and determined by the DIY themselves.
Test PCB board came out
Standard of English is poor, sorry!
The funny part :
A plastic GBU bridge rectifier package has a thermal resistance from junction to case of roughly 9 C/W.
Suppose the diodes inside have a Vf of 1 volt, at full peak current load that translates to 70 W (35A * 2 diodes * 1V)
In free air a GBU package would reach 630C above ambient. :clown:
maybe the Chinese count differently as well.
They certainly don't adopt much of our standards.
