Simplistic NJFET RIAA
Nice work !
Please post some pictures of the pcb (after you etch them).
Yes, it looks good.
But a comment to the grounding: afaik it is not good to change from wide traces to narrow traces and vice versa.
Specially not when currents are flowing, what is the case for the grounding, specially between the bypass caps.
Franz
/Edit: try to explain (afaik): different size of traces is resulting in minimal differences of conducitvity eg. resistance. When currents are flowing this will produce voltage differences on the grounding traces. And this is to be avoided. Better use one trace width, as large as possible.
diyAudio Chief Moderator
Joined 2002
You watch football and blow vuvuzelas, I experiment on phono.:D
