That will increase crosover distortion
Of course, adding the baxandall diode implies adding a third diode into the biasing strip.
Many improvments can be done on this amp, but I want keep basic schematics, work great like old Dynacord. Many amplifier based on this schematics was made latter.Of course, adding the baxandall diode implies adding a third diode into the biasing strip.
Yes, 2SC2922 is better than 2N3773,apex
sir, can i used 4 pairs of 2sc2922 instead of 4pairs of 2n3773???...tnx...
TIP35C can be used with +/-45V DC rail voltage orhi apex, can i use TIP's?
TIP3055 with +/-35V DC rail voltage, two pairs is enough,
how much power can i get with these pairs in full supply...say +-65dc???...
tnxxx...
550W on 4R load is maximum power from this amplifier.how much power can i get with these pairs in full supply...say +-65dc???...
tnxxx...
whoa!!!...this amp really is powerfull for begginers!!!...550W on 4R load is maximum power from this amplifier.
Powerfull but simple, for me amp is amp no metter how powerfull it is.whoa!!!...this amp really is powerfull for begginers!!!...
Useing with protection circuit, no problem, if you like how it sound. You can try it with single pair outputs, it's simple, have a fun.Hi apexaudio
550 watts use for mid-high pa line array no proplam ?
Thanks, be welcome if my expirience is usefull for you,You are a real diyer's gold mine.
For single pair 2N3773 use +/-40V DC rail voltage.
O.K.
I will start with 2 2N3773(old "RCA" labeld types). First i have to find the right transformer in my basement.
regards
frank
550W is maximum power for this circuit, not with +/-65V.550 W with + /- 65 V dc
Regards zeoN_Rider
With +/-65V DC output power will be about 250W on 4R load.
- QUASI Amplifier for Beginners
