Hi apex plz send me the circuit and pcb layout of balanced line input witth 12db/oct at 35hz thanks
If you use ML3 with unbalanced line signal (CD...), input (line-) connect to GND.Hey Mile of Apexaudio, just wanted to say Thanks for all the schematic and board layout. I built the unit and it works great for my needs along with a mono DX Blame-ST amp.
Thanks again
I will, just give me some time.Hi apex plz send me the circuit and pcb layout of balanced line input witth 12db/oct at 35hz thanks
I can't find file with schematics, maybe this can help you.can you post Stereo Tone Control schematics?
No, if you want use left/right balance you must put this 10k pot at the output.apex,
i hope this balance is right,please check
regards
apex,
i am about to begin a guitar amp using this pre amp(from the thread)hopuly a 100w amp,you were right you have too much thread,now i don't know what is the best in this application,the bass amp you post is design for bass,what i'm looking is lead/rhythm guitar amp,but the idea of darlington output is one of the best,
what can you recomend
high fidelity
ax14 or kelvin
150w mosfet
i have plenty of nchannel fets thats why i ask for n fet design,but i'm not off to anything if you suggest,you put darlington output in your bass amp and h1200 because you have greater reason,
hope to hear you soon
regards
high fidelity
ax14 or kelvin
150w mosfet
regards
If you have plenty of nchannel fets, I suggest you to bay pchannel fets, and build http://www.diyaudio.com/forums/solid-state/162081-dc-servo-mosfet-amplifier-4.htmlapex,
high fidelity
ax14 or kelvin
150w mosfet
regards
Stereo tone control with 2x10ki made the stereo tone control pcb board .i have all the parts but i dont have 22k potentiometers at the moment. can i use 10k and change values of other parts?
hi apex i am happy with h900 amp but i want attach the balance line driver and mono/stereo and bridge circuit iwant the pcb drawing plz help me thanks
Hi apex
Im follower of your thread, can i request you to post a simple tone control with bass, mid and treble?
ML3 is simplest three way tone control,Hi apex
Hi apex,
I've checked #7 ML3 . I found bass mid and treble control. Can we have pcb drawing so it could be easy for me to print in the pcb. 🙂
Thank you in advance.
boss ronaldHi apex,
post #1
pcb
landscape
component layout
Yes, will be post soon,apex,
do you have active x-over we can use for b500
pre set for sub purpose
regards
- Live Sound
- PA Systems
- Mic, Line, EQ... Preamps
