LM49720 and LM4562 are exactly the same parts (just a new name) so you can not hear any differences! 😀
Another question: does the 24Bit/192kHz mode work? the old version had a failure with that mode!
the lampucera twentyten arrived today.
just changed the op amp with the TLE2026.
i find it sound well, very well.
spaciousness, articulated bass, and with the new opamp more sweet than the NE5532.
ok, now i little running in.
szia!
szia!
hi tolu,
i don't know the way to test for 24/196.
i know the cs8416 "has born" to work 24/196.
the tle2026? sorry 😱 for my BIG mistake, i use 2 tle2062 and the third a tle2082.
TI excalibur: Precision Amplifier - High Output Current - TLE2062 - TI.com
somebody have tried some modding?
1) glad my newbie ears are honest then 😎
2) 24Bit/96kHz & 24Bit/192kHz flacs both playing beautifully... oy, now i gotta start a silent PC project as i don't have another high bit-rate source! I'll probably spring for a juli@ s/pdif upgrade while i'm at it (unless someone can suggest a good/fast/cheap better solution.
this whole hobby is really getting to be a problem
You can get some free and legal 24/192 flac here :
High Resolution Music DOWNLOAD services
About my passive output project, I got my LL1636 transformers, I'm still waiting for some parts (resistors, box, wires...)
I'll report back when I'll manage to get all of this running together!
me too i'd like use the transformers like output but, i think in my big ignorance, without schematic........... nothing to do.
the first thing for a dramatic improvment would be to replace, if there are, the output capacitors.
usually are elko or worse.
better will be replace it with film capacitors(polypropilene?).
i ask for the schematic to the seller but not news yet arrived.
I got the schematics with the DAC, but it is barely readable.
I asked an electronic version to the seller, but no luck...
I dont' think there are output capacitors.
For the transformers, I took inspiration from this passive output from Rakk :
Passive output
But he is using a PCM1794 where our dac uses a PCM1798.
Smaller output current, so I went to the LL1636 transformer which can be wired as 1+1:10 to get a higher output level. And some 15Kohm resistors for I/V conversion.
I'll give feedback as soon as I have all the remaining pieces.
Passive output
this whole hobby is really getting to be a problem![]()
Try the M2Tech Hiface 24/192 USB Interface! That must be great stuff with ultra low jitter 2.5 ppm!
perfect!!!
but if the computer not close to the amplifier etc etc, all the best can make the M2T will be penalized by the length of the cable to connect the "audio system".
or i mistake!
most probably an AES/EBU cable 110 Ohm will nullify less than a coax cable 75 Ohm.
maybe.
perfect!!!
or i mistake!
maybe.
I was thinking of the BNC version... my cable run is about 4 meters (i know, i know).
anyone tried this PCM2902 USB->S/PDIF from China? Cute little bugger...
PCM2902 USB to S/PDIF Coaxial Audio Converter SKU64 - eBay (item 230410109033 end time May-07-10 20:45:08 PDT)
Sample Rate: 16bit / 32K, 44.1K 48Kanyone tried this PCM2902 USB->S/PDIF from China? Cute little bugger...
It's a bit sad as your dac can handle 24bit/192K.
As we say in Germany: pearls for the pigs! 😀
Perlen vor die Säue werfen.
Hopefully nice square pearls.
gonna pass on that and get the M2T thing in BNC.
Man the DAC with the dual Burson even makes MP3s sound fairly decent. Gonna def order some Sanyo Os-Cons for board per Lampizator... but not sure where to put 'em since his site refers to the older model. Hopefully someone will stumble upon this for guidance.
Put an old Musical Fidelity tube buffer between the Gigawork DAC and my amp but i'm not noticing much improvement, possible muddiness/cloudiness/warmth and i think i prefer it without. Hard to tell honestly as it takes time to swap cables.
No upsampling, but does natively handle up to 24/192.
However, there is internal oversampling in the dac chip.
maybe the musiland sound card will be better?
but there is always the unknown of the cable.
al the improvement can be lost.
- Digital Line Level
- New Small DIY Gigawork Dac?
