900W H-class PA Amp with Limiter
hi apexaudio
greetings today powered amplifier on series bulb is glowing
` very weak audio voltage seem's to be collapsing both high and low can u please give some tips on how to find faults
thanking you
Andrew lebon
hi apexaudio
thanking you
Andrew lebon
I can't see all conection from PSU, do you conect GND from PSU to input GND with separate wire? Do you have wire jumper on coper side pcb? Can you post lighter picture.
apex,
apex,
sir, without the presence of NSL32 on board, replaced with a normal LED and LDR enclosed in a black pipe, can i add another LED in parallel as clip indicator???...that would be two LEDs, one as clip limiter and another is clip indicator...
tnx...
