Around 24V and 200mA is somewhat of a sweet spot for this regulator. If you don't have much experience with this if I may suggest, build the simpler one first, the Salas simplistic v1. You will be amazed by its performance.
actually it s more 200ma per channel so i d like 400 to 800ma. and +-30V would be preferable. but if there are odds that it s a bit more difficult to build than salas shunt, i ll take the latter. honestly, it was pretty much heads and tail when i chose which one to build.. as you said and as i read, i shouldnt worry about the performance so...
still salas shunt cant do 3.3v as he told me. so you are my last hope 🙂
also if 200ma @ 24V is tricky, coundnt i just raise the sink current, thus id just raise the ccs current?
Hope dies last 😀
Wait a minute, you say you want 3.3V output voltage. Why are you talking about +-30V?
sorry my bad. i d like a 3.3V reg for my dac that can do let s say 100ma and a +-30V that can do 400 to 800ma
stormsonic built a nice one for his dac, all smd though, so, do you have tiny hands? 😀
stormsonic, are you around?
my palms are 83cm wide and i d consider i have relatively small hands. i can send you pictures if you want. but with gloves of course not naked!
so bring it on! 🙂
so, is +-30v .4A to .8A possible with good stability?
so bring it on! 🙂
I don't have a thing for men hands, no need for pics 🙂 Let's wait for stormsonic see if he gets on tonight.
D2 & D3 can be replaced with single LED. C2 can be increased to 47uF or 100uF.
R17 need some tweaking. Exact value depending of D1 voltage forward and Id of J5.
Tested without C3 capacitor, it is stable. Current should not go over 100mA.
I think this shunt reg would make a nice upgrade over the linear +/- 15v
supply in my active xover.
The xover has all its buffer and pass stages built around a discrete
opamp (6 per ch), and I'm considering individual pos/neg shunt regs for
each opamp.
But I'm wondering if this reg's low output imp. and remote sensing largely
cancels out any benefits gotten from individual regulators.
each opamp.
hifinutnut I think is using it or wanted to use it in an active cross over. What individual regulators did you have in mind, to compare with?
I'm sorry, the individual regs I was referring to is your design.
So, I was considering putting smaller 40 mA regs at each of the 6 opamps
instead of one 240mA reg per channel.
I'm just not sure if there was any point to doing this since, if I understand correctly, the remote sensing makes the different length runs from each opamp to one main reg somewhat irrelevant.
Hi, guys,
I am spending 90% of my SPARE time on my "bread and butter" work now and only 10% on DIY. But will cut the boards today and build 3 x +/-15V regulators for my active XO in the following weeks. I think if ppap64 wants 6 regulators for 6 opamps it may be a bit overkill. I can tell you my result in about a couple of weeks time.
Ikoflexer,
Here is one suggestion: we have gone through those before but I think it is very convinent if you inidcate the ideal Idss (or Idss range) of the jFETs directly on the schematic so that we don't need to go back to the previous over 1000 posts trying to dig out the information, which is something I have to do now. I remember for J2 and J4 they would be 7mA to 8mA, or not? 😕
Bill
Ikoflexer,
Bill
Will do Bill, good suggestion!
ppap, people have reported elsewhere that individual regulators make a positive difference. I haven't tried it myself, but at least some top end devices do it that way. Another way to do it is to have one common CCS module that feeds a bunch of individual shunts.
Wow, there's a great idea, cuts the mosfets needed about in half and simplifies the layout.
Thanks Iko.
Thanks Iko.
Better to have 1 common preregulator, (LM317 or cap multiplier or.....anything), feeding individual CCS + shunt.
Different circuits (loads) will interfere with each other + sharing current paths is not good. CCS will provide isolation between those loads and should not be common. Loads should not see each other, they must be isolated.
- Power Supplies
- My take on a discrete shunt voltage regulator
