Simplistic NJFET RIAA
Hi Guys,
PCB with star power. Maxpou
@massimo & maxpou
Seems that all our new project is 60 dBs, why not share the design & cost to make a professional pcb?
At this moment we are 3.....
Too much trouble and expensive.... at least for me.
Secondly I'm designing my own pcb for my components and case. It won't be "universal" at all.
When tested, I'll publish the layout and everybody can do their own homework 😉
In the shunt reg: base/grid stopper are cheap carbon 1/4W pitch 10mm, other resistors Dale 1/2W p.12,5mm. Wima caps (possibly) p.27,5 or 37,5mm and Bourns trimmer
In the RIAA: Dale 1/2W p.12,5mm and 1W p.17,5mm. Elcaps Silmic II. RIAA network: teflon caps (pulled out from an old ML phono board) p.17.5 or 22,5mm. Coupling cap: Russian FT-2 (body 20 dia x 52 mm) p.55mm. Output cap: Obbligato Premium (body 25 dia x 50mm) p.60mm. Both mounted under the pcb for minumum tracks lenght (as Disco did in his pcb).
In the shunt reg. v1.2 the Wima caps will be MKP 4.7uF?
In the RIAA mine silver mica russians caps are p. 11 mm instead 17.5 or 22.5mm so can be used, coupling teflon caps FT-3 are body 27 mm x 53 mm so will be more or less the same than FT-2 if you do p.55 mm, p. 60mm for output cap allows use several kind of types.
Did you compare Obbligato vs Auricap, Rcruz uses also Obbligato, hear that Mundorf are vey good but are very expensive for mine pocket, actually I use Auricap 3.3uF with good success.
I bought a pair of 3,3uF Obbligato Premium because of (or thanks to) Ricardo.
I discovered later that a friend of mine is importing them from HK. He also does Mundorf and he told me that many people who bought them said they "fight" closely against the Silver Gold Oil series for a fraction of the price. Auricap: never tried, but Air Tight uses them and I like their products.
On e-bay is DIY-hifi-supply Hong-Kong the seller.
I listened a clone of Audionote Ongaku with a couple of 211 but tubes aren't for me. Mine prefered tube is E34L Tesla configured in triode only 1 tube single-ended class "A" good sound but only a few watts.
No problem, when your PCB is ready let me know exact p.
