MOSFET Amplifier IRFP240/IRFP9240
Clip indicator
If no signal on the output of amplifier voltage on point 47k,22k,10R,10uF is 25V to the negative rail, BC546 is on and short circuit led diode, current go thru GND 10k1W CE of BC546 to negative rail. When voltage on output is about -65V (-75V rail voltage), voltage on point 47k,22k,10R,10uF is 10V to the negative rail, and in the point 22k,1k5,base BC546 is 0,6V to the negative rail, BC546 off current go thru GND 10k1W led to negative rail, and LED light. 10uF give some time delay for short peaks. Sorry for my English.
Regards Mile
