Amveco toroid boards
I can put it in and if you don't need it, just jumper it. Does that sound good? Shurter OGN fuse holder looks nice, and you can put an isolation cap on it if you want.
http://www.schurterinc.com/pdf/usa/c_ogn.pdf
Measurements are:
Single: 78.74mm x 88.9mm
Dual: 139.7mm x 88.9mm
Tripe: 200.66mm x 88.9mm
That sounds good. 😎
I accidentally have some of those fuse holder in my parts bin.
yep that shurter part is just right; excellent mate, I was hoping that you might still be able to drop it in. that was the idea, too to enable it to be simply left out of the circuit if desired by the use of a jumper. thanks for the transformer info,m there are literally thousands of PCB mounted trannies at digikey
Got my boards today thanks! Very nice!
Can't wait.
Got stuff here, eagerly awaiting some juice :drink::
