Ultra high precision digital control attenuator
Do the pretty pitures somehow indicate "goodness"? I bet a $2 pot has less distortion and noise. In what way was the multiplying dac better? Distortion?
Those pictures are very close to perceived quality, verified by tests, believe me.. $2 pot is much worse in channel tracking, crosstalk (and wit usual values as 10-50kohm also in noise).Distortion is dependent on active devices, similar for both solutions.Multiplaying DAC was better in distortion at high levels (above3-5V RMS) an frequencies around 20kHz. IMD 19+20 was better, too.
Do the pretty pitures somehow indicate "goodness"? I bet a $2 pot has less distortion and noise. In what way was the multiplying dac better? Distortion? It obviously uses some very dubious resistors.
PASSIVE ATTENUATOR is bad in ultra-low level condition, balance for L&R,noise sensitve etc
the passive potentiometer even can be configurate a LOW-PASS FILTER with the Capacitor in the output
http://www.diyaudio.com/forums/atta...ion-volume-module-like-mark-levinsions-p1.jpg
picture for the system
I just got the AP measurement from my friend
the module reaches a ultra-high performance in ultra-low level conditions
FFT @ -80dBV 1KHz
we can see the noise floor is below 1uV with balance output
