Coax drivers for home audio?
Wave guides are all the hot design for home audio right now. Everybody is experimenting with them with everything from 1 inch compression drivers, to modifying them to accept hifi domes. Emerald Physics and others have also gone one step further by incorporating the concept into a large coax.
What are the best coax drivers available to DIY for home audio? Does anybody know which driver Emerald is using? I see most of the pro coax speakers use a 1.4 inch compression driver with big power handling that I won't need and bass tunings for a two way which I would rather cross at 2-300 to the bass drivers. I'm looking for quality over quantity. Any ideas?
B&C closer
The B&C is getting closer to what I am looking for and the price is about right. FS, Xmax are all about right. Now if some one will forget power handling and put some real hifi smooth response into a package like that we will be set.
I've used several 12-15" cast frame Eminence - not sure how you would like its horn - - martinsoundpro probably has 1114 12" coax with 80oz magnet and edgewound coil around $120 retail(?) APT50 compression driver will work ok. BMS has some nice looking coaxials over at Assistance Audio - I would have tried one but want lower mms for Karlson couplers
Martin 1114
Tom Danley mentioned that all coax have problems, and the least one was an 8" B&C. However, that was mentioned some time ago.
I've been looking for a pair of 12" coax to do a small OB to hang in my room. So far, I have not found any evaluation of the current ones. I'm tempted to buy a pair with small waveguide in the middle so that I can test stuffing foam with them. But they cost $900 a pair.
I've been to a few clubs in Las Vegas. Their CD sounds horrible. The worst is at PH.
Sammi has these. Not a bad driver at all. you have to do your own XO but I've heard that some use a simple cap and are happy.
WELCOME TO SAMMISOUND
