I don't believe cables make a difference, any input?
Neutral in the sense that there is a minimum of dielectric material used, all with a very low dielectric constant, the Litz type 1 weave makes them relatively immune to any airborne RF and you have to drape them across the top of a power transformer before they will accept a 60 Hz signal, just draping them next to a power cord won't do. The use of #40 gauge wire ends all discussions about "skin effect" and the Litz braid, without any woven shield, and a cotton tube eliminates the need for care about external capacitance, like nylon rugs and other audio tweak needs. They don't change their character audibly between 3 inches and 3 meters as interconnect wires. And, the character is a lack of any readily audible sonic signature.
Simon has already offered to test them so we would have objective data to utilize. I am not offering these for sale, by the way, they just come from my own anecdotal research into how cables and transformers interact., or don't. These don't seem to interact with anything, the copper is commercially pure and the other audiophile bugaboos are side stepped.
Bud
Fantastic Dave! So, what do you make of all these online anecdotal testimonials/reports/tests about EnABL?
They are just as scientifically significant as the 95% of DBTs. But they do make you think. I have participated in blind tests with level matched pairs of treated vrs non-treated where the setup was done by 1 person who was absent during an AB test that involved switching from one speaker to another. It was clear to me, on a personal level, that the differences went significantly beyond adding the same amount of mass.
dave
thanks dave for popping in and setting this wayward thread on a more rigorous path.
I disagree... i thot some people were just being thick, i had no problem understanding,
dave
Sure they do. A positive control is a test to make sure that your test can detect anything.
dave
Exactly what i said in less explicite terms...
dave
See, maybe that's half the problem that made you think you were on a white charger and saving us...and here you are thinking you had the same concept as SY's, and 'lecturing' us on how much Jakob had to hammer a point home.
sheesh. trouble is, you probably DO think you said essentially the same thing as SY. (fyi, you did not)
This is exactly the positive controls that Jakob2 has been hammering away for the last 10,000 posts.dave
dave
Ahh. Same as the dbt's you disparage eh?
Whilst you're on this kick, howzabout giving us your evaluation of all the anecdotal cable differences heard. How about you be consistent and help us point out to the cable guys that their anecdotes have no scientific basis.
You can be objective yes??
Neutral in the sense that.....the character is a lack of any readily audible sonic signature.
So they are "neutral" sounding....because..they are neutral sounding? 😕
Bud, Simon could measure the effect of the moon and sun on the d*mn wire, how is this correlated to audio?
Bud, we appreciate your offer, but if there is unanimity on something, it's that audiophiles can't agree on anything. They are in complete disarray as to what is good, what is great, let's eat some chocolate cake. One audiophiles bugaboo may be an others salvation.
Do recall that Tom already has wires he can hear just fine. 😉
IOW, according to you, worthless. Ok. (won't bother to ask for evidence of how the 95% figure was derived).
Level matched? You mean average level closely matched? Added mass/damping/stiffness will affect HF predominantly (though not exclusively). So you could have same (or close) average, but different FR. And that is audible. So...???
Ah, so you know exactly how much mass the EnABL process added. Excellent. Ok, how much was it?
When this precise amount was added via process B, what process was this....and how was it sonically compared/tested (scientifically significant) vs EnABL?
TIA
What was much more audible is the big difference in 3D soundstage, something not really affected by the FR but an indication of greater downward dynamic range.
Limited as it may be, i do have data, you just have a WAG based on nothing but preconceptions.
Enuff of that thou. This is a cable thread, it doesn't need any help being controversial.
dave
I don't remember asking you for your permission AJ.
The neutral comment is derived from my firm knowledge that only LCR affects can be found to alter the measured response of cables. These particular cables have the least C possible in the real world. Their L is fixed by their type 1 Litz geometry and their R, both RAC and RDC is as low as a cable with similar circular mils of area can be in the audio reproduction realm.
I am equally sure that only LCR can possibly have any audible effect upon an AC signal passing down a wire. My offer is made because this is as little real world LCR as you can get, without falling into SY's pathological classification, and since they should have considerably less LC and RAC / RDC than the test cables that Tom is intent upon using and there is a commotion about a positive control, I cannot think of a more neutral positive control than what I have described. If you can come up with one that betters these parameters please provide us with your choice. And no, Mogami cable cannot be used as a control, because it is as suspect as the cables Tom is intending to use. Neutral means just that, as little alteration as is practically possible for a positive control, either objectively, from Simon or subjectively from anyone who cares to listen to them.
Bud
Earl, I can't believe you've allowed yourself to be drawn into the madness of this thread. That said....welcome. Enjoy the laughs with (some of) us 🙂.
cheers,
AJ
Hi AJ
I should know better, I know. Sometimes I can't help myself. I see a child drowning in a septic tank and I just want to help. It's always such a disappointment when you find that they jumped in themself and they seem to like it!
bud, is your offer meant to provide a counter to the ones Tg will be using ?(afaik, he has that already picked) or to be the reference for tom?
Dunno what has been picked as "B' (toms current ones will be "A' I spose) but I would have thought bog standard el cheapo wire??? Now that you have brought it up, what will be the alternative? Sy? TG?
Anyway, my only concern is the extra time it may bring if you (others) pop in with cable offers etc etc.
TG has to do his practice, get the procedure licked and all that stuff. He has spent a while getting a handle on the sonic properties of his new cdp, and hopefully very soon onto the training!!
Have you decided TG (SY) what the alternative ICs will be?
Bud, one thing that grabbed me from your post was 'I am equally sure that only LCR can possibly have any audible effect upon an AC signal passing down a wire.'
I asked that question a few pages ago, to date no-one has answered. Thanks. (Just for the record, the question was 'for the cable believers, is it possible that if you do hear cables, it is a sufficient mechanism that the audibility is due to lcr differences only'? ...ie do we need the cables seller voodoo or not, or is there truly new things that science needs to discover)
Though generous and helpful, that's exactly the opposite of what a positive control is.
Here's my suggestion: send a pair to Tom and he can listen to them. If he feels that these are what he wants to use for one of the DUTs, that's his choice. If not, he can use whatever he feels he can readily distinguish without peeking. I honestly don't care which cables he uses, I want HIM to choose what HE thinks will show the non-mundane effects he believes that he's hearing.
Wow, can't believe you would slam SY and especially Tom like that. Poor setup/equipment and no training? Yikes.
(Btw, SY was committed? To what institution?)
AJ
OK, I can provide some very neutral sounding cables, Litz wire type 1 lay up using 140 strands of #40 AWG, four nines copper coil winding wire as the cable, slipped into cotton tubes. These could be measured by Simon and sent on to Tom for audition fairly quickly. Or, we could ask Steve Eddy to make some of his Milliot woven cables, again Litz and cotton. Free of charge on my part.
Bud
Bud, if you have a spare set available sometime, I would like to have a listen.
It was with mercury switches. 30 years has not changed much. Show me what has been changed, please. Is there any low level contact better than pure gold for relays, pure silver for switches. 30 years is a a long time, but I doubt it. Please prove me wrong.
What would 30 years change?
A new test would have:
a) A modern test protocol
b) An independent proctor
c) Documentation
All lacking in 30 year old remembrances.
