So im looking to build a cheap 1-2watt very small mono desk amp.
Something like a 50EH5 or 6T9 (still accepting recommendations)
What im really after is a speaker for the project. The cabinet needs to be the foot print of a clock radio (smaller then 10" by 6" preferred) and it only needs to play radio freq range (100-120hz to 15khz or so) and is only going to be 3ft away from the listener.
Any recommendations? I was thinking of a tangband or fostex. These seem to fit the bill but all the cab designs are huge and are designed to play down to 60hz.
How about some of the OB speakers gainphile has built? You could also go cheap with a Tangband full-range or expensive with the Jordan JX92S. You might want to ask your speaker questions in the appropriate speaker forums on this site. You'll have a higher chance of getting useful answers.
For the amp, you should be able to get 4-5 W out of a 6LU8 (or probably 6T9) spud in UL mode. I'll be posting the final design soon. You can get a primer here: 6LU8 Spud RFC. You could also look at the Tubelab SimpleSE.
~Tom
~Tom
The simple se is in the works. However it will be over $300 and be 20lbs. Im looking for something very small to put on a desk at work that will replace my beloved clock radio (old tube radio that got dropped and shattered into a million pieces).
You want baby Amp 🙂
Baby SET
Pics:
Classic Valve Design - Chinook S.E.T. Amplifier
There's a 6AH4GT version earlier in the thread too.
Cheers!
Baby SET
Pics:
Cheers!
For the speakers I built the micro-fonken by planet10 full range. I was really surprised !
Best Regards,
Davide
Best Regards,
Davide
Well since the big guy replied. If i was to make a uFonken, do i just buy a fostex of the right size from madisound and call it good, or is there a small baffle step cross over i dont know about?
I did them with the standard Fostex and plywood I paid 3 $. I think it was the only project I made without spending a fortune.
D.
D.
You need the FF85k, either from Madisound, or all tarted up from me.
You might find that 1 w & these are a bit limiting unless you are using them nearfiled.
Any of the other more efficient 3" Fostex need a box about 2x as big to get the same bass, and at that point, one can get FE103 (or better yet) FE127e into that small a box for a lot more bottom end and even more efficiency.
dave
Planet10, I never had time to thank you, but that speakers are really amazing.
I am glad you like them. They are really surprising. The looks on people's faces when i fire them up in my big room is very satisfying 🙂
dave
RE:
Oooops! Here's the last schematic I used... the other is out of date:
Baby Amp II - The Rebuild
Cheers!
You want baby Amp 🙂
Cheers!
- Tubes / Valves
- 1 watt desk speaker
