Gb: F4 pcb
Hi All,
I have been asked quite a few times if I had any F4 boards available or if I would do a GB. So after having enjoyed doing the http://www.diyaudio.com/forums/group-buys/134554-gb-f5-pcb.html, I could just as well make some F4's. ;)
In this thread, I would like to hear if people would be interested in such a GB.
Here is the service manual btw:
http://www.firstwatt.com/downloads/f4_om.pdf
Christian
Hi Christian,
I am curious what PCB CAD program is used to create such realistic looking PCB layouts, it looks really good!
Cheers Michael
I already have the F5 PCB. I tried to get yours, but you were sold out so I went on E-bay. I think I'll get your F4 and a F3, and try them all. I needed to get two mono blocks with four 10" X 6" Heat Sinks. I already have the chassis and transformers. Your PS PCB were for stereo, so I had to get single ones elsewhere. If I can I'll put all three in the cabinets. The boards and components aren't that expensive. The power supply and the rest of it are all the same. I sure want the F4 to work. What do you think?
Ray
Just got a package with a lot of boards today. :D
Hi All,
Christian
I sure would like to order some F4's. Do you think this project would work:
"I already have the F5 PCB. I tried to get yours, but you were sold out so I went on E-bay. I think I'll get your F4 and a F3, and try them all. I needed to get two mono blocks with four 10" X 6" Heat Sinks. I already have the chassis and transformers. Your PS PCB were for stereo, so I had to get single ones elsewhere. If I can, I'll put all three in the cabinets. The boards and components aren't that expensive. The power supply and the rest of it are all the same. I sure want the F4 to work. What do you think?"
Ray
