Hi to all,
witch Electrolytic Cap after the rectifier do you prefer for low-power usage (max. 25V) ?
Feel free to vote and post your thoughts.
Best regards,
Oliver
Best regards,
Oliver
I've seen a lot of those "witch" Fuhjiyus causing power supply failures. I prefer to replace those with Sanyo OS-CONs.
I was tossing up between Panasonic FM and the Nichicon FG, neither of which I have used (have used the Panasonic FC's)
Geek the FM's have a lower ESR than the FC's according to the datasheet 40-70% Less!
I just checked the max value at 25V and it is only 2700 uF The FC's go up to 5600 uF at 25V and the nichicon FG's 3300 and the rubycon ZL's 2700uF so depending on what values you need the choice may need to be made based on what values you can get! in each series...
Tony.
Tony.
Tony.
Hi Tony,
don´t think much about the max. capacitance at 25V. If i would like to have more, i could insert an additional cap. 😉
Therefore i limit the question only the voltage.
Best regards,
Oliver
Very cool! 🙂
I shall checkout my suppliers for these.
Cheers!
Nippon Chemicon LXV, LXY and LXZ
I believe KZE is the best of Nippon(United) Chemicon
Rubycon ZLH, ZL, YXH work excellent for me. I think they sound more neutral than the Panasonic FM and FC.
Joined 2003
Panasonic FM or UCC LXZ. The LXZ seem to have the same specs as Panasonic FM, but rated for longer lifespan.
- Design & Build
- Parts
- Witch Electrolytic Cap after Rectifier for Low-Power usage?
