The only differences they detect are like comparing a minibus with a train. 🙂
Really? 0.3dB level difference is minibus/train?
What 0.3dB difference you are talking about?
No that's not my intention but I've read DBT's where the listeners couldn't even hear differences between different speakers. 😕 Either, it was a poor test setup or the listeners didn't have a clue what to listen for. These 'tests' then get quoted to prove a point. Remember the "all amplifiers sound the same" fairytale?
I would rather do my own testing.
Yes, bad tests are being done. So? Does that mean that the concept is bad? Of course not. And still, even if someone does a bad test, is that a reason to call all pro-DBT's deaf or clueless?
You don't need that Andre.
jd
jd
All I'm saying is don't believe everything that you read, first check if the test is done in such a way that it is possible to get a correct answer. Some only stare at these 'tests' and never think or try for themselves.
Have you visited linked page?
Agree, yes, OK.
jd
And it is indeed hilarious to read the shuffling and ahem-ing when something which is clearly a terrible component gets a rave "subjective" review.
Yeah. The best example of that perhaps being the review of the Harmonic Technology CyberLight interconnect cables.
JA at the end of the measurements section:
If this review were of a conventional product, I would dismiss it as being broken.
MF from the review:
No matter how I try to deny it, after many months of listening to these cables with a wide range of associated gear, their superiority to anything else out there that I've heard is undeniable.
Basically the CyberLights were a fiber optic analog cable that used electro-optical converters at each end to convert from electrical to optical at the source end and optical to electrical at the load end.
They had a decidedly non flat frequency response...
And produced gobs of harmonic...
And intermodulation distortion.
When they review woo-woo stuff, do they also do measurements?
No. They only do measurements on regular electronic components. They don't even do measurements on regular interconnects and speaker cables, but an exception was made here seeing as the cables were in fact electronic in nature.
se
Odd definition of shuffling. They always give precedence to the reviewer's listening but Atkinson will voice his opinion on the test results, pointing out both possible corroboration and conflict. Wavac is another example. Measurements take a back seat as a matter of policy, just because you disagree with that policy doesn't make it ambiguous or dishonest.
You guys kill me. They published a suite of measurements that put Fremer in a very questionable light and you rag on them? Is Hirsch the prefered model, publish only happy face results from advertisers? Here's Atkinson's FULL comment on that cable, bolded for honesty:
And you claim the voice of science?
"If this review were of a conventional product, I would dismiss it as being broken. Ultimately, no matter what someone might think of its sound—and Michael Fremer is one the most skilled listeners I know of—I really don't see how the CyberLight P2A and Wave cables can be recommended. I am puzzled that Harmonic Technology, which makes good-sounding, reasonably priced conventional cables, would risk their reputation with something as technically flawed as the CyberLight.
"If this review were of a conventional product, I would dismiss it as being broken. Ultimately, no matter what someone might think of its sound—and Michael Fremer is one the most skilled listeners I know of—I really don't see how the CyberLight P2A and Wave cables can be recommended. I am puzzled that Harmonic Technology, which makes good-sounding, reasonably priced conventional cables, would risk their reputation with something as technically flawed as the CyberLight."
Don't know what you mean, but I read this statement as that the cable is technically deficient or bad or broken etc, whatever one may think of the sound. In other words, one may have whatever opinion about the sound, the fact is that technically it's broken, technically flawed, as shown by the graphs above. Is that not how you read it?
jd
Yes I did, thought you were talking about the amplifier comparison on that page. 😉
Yes, it is an odd definition of shuffling.
Why?
Because my post was never intended to give any sort of definition or example of shuffling.
My post was given only as an example of "something which is clearly a terrible component gets a rave 'subjective' review."
I thought that would have been rather obvious to anyone who read my post seeing as all I did was quote JA saying if it were a review of a conventional product he'd dismiss it as being broken, followed by a quote from MF saying they sounded better than anything else out there, followed by the graphs to illustrate why JA said what he did.
Nothing more, nothing less.
How you managed to get from that that it was supposed to be some example of "shuffling" is beyond me.
se
jd
Yep, and that Atkinson makes the same observation and recommends against the product.
When you data mine, don't forget your helmet.
Fremer seems to make a habit of this stuff:
Stereophile: KR Enterprise VT8000 MK monoblock power amplifier
....OK I've listened to some 'hi-end' stuff that would be better described as mid-fi 🙄 but thats besides the point.
I guess you called it "hi-end" because of its looks or price.
On what basis does he recommend against the product?That Atkinson makes the same observation and recommends against the product.
I wasn't the one wielding the pick, just commenting on the nuggets.When you data mine, don't forget your helmet.
Trick question Bas?
I see. So you didn't read the entirety of my quote from SY.
Try being a little more thorough next time.
se
As long as we're piling on here, there's also the review of the $300,000 Wavac SH-833 monoblocks.
I begged for another month with the magical Wavacs. I was lucky enough to get it.
Edit: Oh, and this review does give an example of what one might call "shuffling."
JA:
I can't explain why Michael found its sound so seductive; all I can do is point to the measurable problems or audible idiosyncrasies that must be listened through to hear what it does right.
That's the classic "shuffle." That the thing must be doing some unknown "something" so right that it manages to effectively negate the huge pile of things that it does wrong.
se
se
Yes, I did, and nothing further modifies or counters the opening statement. Maybe I'm ESL, enlighten me.
SY, an example of 'shuffling' from your nugget:
After I informed him of the apparent instability problem with the first sample of the VT8000, JA wondered if the amplifier was broken. But other than a reduced tendency to oscillate, the second amplifier did not behave in a significantly different manner, which led us to believe that we were measuring representative samples. Given the VT8000's low power, high source impedance, and potential instability, its test-bench results are disappointing, particularly in view of its high price.—Thomas J. Norton
- Design & Build
- Parts
- I don't believe cables make a difference, any input?
