Gainclone Transformer
I'm thinking about making a dual-mono lm3886 setup using kits from chipamp.com.
Does anyone know of a cheap toroidal transformer for this application? 1 per channel would be okay, but dual secondaries on a single toroid would be perfect. Any ideas?
A monoblock needs a dual secondary transformer to produce a dual polarity supply.
You can achieve very similar with a centre tapped secondary.
A dual mono would need 4 secondaries to achieve dual polarity supplies for each channel. But, it would not be a dual mono any longer because the two channels share the primary and the core.
TWO of these: Antek - AN-2225 pair of 25+25 vac, 200va transformer
will make dual mono, and that is the answer to your question because they are what fits the chipamp.com dual mono kit.
For reference, ONE of these: Antek - AN-3225 25+25 vac, 300va transformer
would fit the chipamp.com stereo kit.
I would also like to mention:
1). Arctic brand CPU paste (has filler properties) to use with LM3886TF chips (which are covered in coarse plastic).
2). A nice big heatsink, the bigger the better.
3). Air inlet at the bottom of the enclosure (preferably underneath the heatsink), plus, air outlet at the top (or highest point of the rear panel) of the enclosure. Let the cool air in at the bottom and let the hot air out at the top so that the amplifier enclosure isn't an oven.
4). Place the input filter cap between the potentiometer and the RCA Jack (not between the potentiometer and the amplifier). If you don't plan to use a potentiometer (because you have a preamp), then add/substitute a 22k resistor (as a load) between Input + and Input - in order to maintain the integrity of the design. aka, the chipamp.com kit specs about a 10k input load, half of which is the onboard 22k resistor and the other half is the expected 20k potentiometer. Frequent reported problems with DC offset are because of input loads with higher figures than 10k (or 12k).
5). The capacitor for speaker output zobel (output RC) included with the chipamp.com kit is the wrong type. An inexpensive little polyester/mylar dip cap is typically used for zobel, not high-efficiency polypropylene, so if you get poor quality upper treble, then replace that little cap. 🙂
P.S.
Terminology:
The chipamp.com kit isn't a gainclone because its very much unlike the 47 labs original.
The audiosector.com kit IS a gainclone because its quite like the 47 labs original.
okay, I understood how many secondary lines I would need, even if I don't quite have the terminology yet.
Would using a transformer with 4 secondaries reduce the output or each channel?
It's interesting how versatile the LM chips are, National's basic schematic is a great design, I'm not sure about the Gaincard, never seen or heard one, but it has really added to the DIY community with all of the different Gainclones out there.
Thanks guys, I'll look them up.
At this point I just don't want to be paying more for the transformers than the kits, but maybe that's just how it has to be.
Most people use between 120va to 160va transformers for stereo LM3886 builds. A 200VA Antek or two 100VA Anteks (for dual mono) is plenty.
Also, if you're in N. America, since the Antek's are rated at 50Hz, you'll get a 10%-20% increase in available current output when running on 60Hz. So that 200VA is now a 220VA-240VA transformer.
Usually, the amplifier board and power supply board is the least expensive part of the amplifier.
Better than anyone else's recommend, you could just find out the exact parts (transformer model#) that the kit manufacturers are using in their own homes. Chip amplifiers are extremely sensitive to differences. So, the "real" most economical thing to do is to start out with a "known good" configuration as specific as possible.
Generally speaking, it can be unseemly to use Smaller than 120va transformer with chip amplifiers, because smaller transformers have thinner wire and a tendency to ring (aka boomy/weak bass, weird mids, etc. . .) along with other noticeable frequency response artifacts. Larger transformers (within reason) are less trouble.
I went to Antek's site first and found the AN-2225 just from what I new that I would need, didn't even notice the recommendation. 2 transformers for under $100? Perfect!!! Bookmahk!!!
Thanks for the pointers too, especially about the filter caps and replacement caps.
It'll probably be a couple of weeks before I'm done with everything, I will make a post in the photo thread when I am done.
Thanks guys!
Was searching for transformer info and came upon this thread.
Saw one of the posts by danielwritesbac that peaked my curiosty
the quote from one of his posts above:
P.S.
Terminology:
May I ask.... in what way is the chipamp.com kit/amp unlike a 47 labs original and likewise
how is the audiosector different from the chipamp.com making it more like the 47 labs original?
Is it as simple as the fact that the chipamp.com uses an LM3886 vs the original using an LM3875 or is there more to it than that?
My apologies if this has already been discussed to death.
regards
Curt
P.S. I have some unbuilt chipamp.com boards (LM3886) and was trying see what it would take to build the project.
I'm curious if the chipamp.com kit, like the audiosector kit, was meant to be a dual mono and compact-specific design. I bought the stereo chipamp.com kit and I believe that the screamingly loud mids tone is counterproductive for music. The bus (not star) layout, the undersized NFB cap (bass block) and the undersize 100u (clearer Louder mids) amplifier board power caps seem to be the main causes, and Natsemi Spike hard clipper also contributes somewhat increased audio distortion if there's any loud playback.
Natsemi in their AN1192.pdf advises minimum of 470u power caps directly at the chip (aka amplifier board power caps). This specification partially fixes the chipamp.com stereo kit, although while 470u apparently works for parallel amp projects, maybe 1000u could be nicer for solo chips as seen in the chipamp.com kit.
I'm speculating that the dual mono kit could dull out the screaming mids by having a power board not more than 2mm away from the amplifier board. These boards are made to line up and be used as one unit. In that case, the 10,000u caps are close enough to, perhaps, swamp some midrange distortion. Hopefully, the dual mono system works well when used in compact layout--large capacitance close to the chips changes it to a "gainclone." Probably then it succeeds with inoffensive music playback. Adding up all the clues, results in 10,000u||1000u amplifier board power caps, same as the MyRef's power circuit.
P.S.
The chipamp.com kit does seem useful for television. Personally, I'd much rather have the high-end made-for-music NatSemi LME chips for a more pleasant experience with music playback.
Hi Daniel,
Comparing LM3886 dual mono kit (snubberized PS),
from Chipamp :
http://chipamp.com/docs/lm3886-manual.pdf
and Audiosector :
DIY Chip Amplifier Kits, PCB's, Components and Information.
I don't see big difference, so I think the sound of two kits are very close ?
If I understand well, you said that "10,000u||1000u amplifier board power caps" sound better, maybe much "warmer" like LM3875 ?
Phil.
PS : 2 weeks ago I build amp with Chipamp kit:
http://www.diyaudio.com/forums/chip-amps/79303-chip-amp-photo-gallery-280.html#post4106047
P.S.
Terminology:
Thank's for the info. I have just ordered a dual mono kit from chipamp.com. Unfortunately the shipping of the transformers is too expensive from the US to EU so would this locally sourced transformer do ? I am a total newbee with toroidal transformers. Have only used SMPS's so far in my kits.
:joker:
Buy Ring core transformer 200 VA 24 VAC (2x), Noratel, AA-58049 RM | Distrelec Switzerland
Daniel said that in January 2010, maybe actually it's not the same ?
Today it's Vishay :
BC / Vishay 0.1uF Capacitor | Chipamp Electronics
But for Cz, what do you think of Vishay Ero MKP 1837 or Wima MKP 10 ?
Phil.
C'mon, gimme a break 🙄
It's a high impedance over all of the Audio range, 80 ohms at 20kHz , in parallel with a 4 or 8 ohms speaker, and driven by a very low internal impedance source, the chip amp.
Won't be a significant load (say, 8 ohms) until you reach 100 kHz 😱 .
No possible audible effect ... unless you skip it and the amp oscillates ... but that's another problem.
Polyester/mylar/polypropylene, even humble ceramic, are perfect in Zobel networks.
Any small internal resistance variation is swamped by the typical series 10 ohms.
