Lotus BVR/CHR-70 - Question about suitability
Well, no FR based system is ideal for the kind of material you favour; OTOH, I'm often to be found listening to the same myself, so providing you accept the limitations in advance, you should be fine.
May I ask what kind of system is ideal for the favored material? I have a genuine interest here - I suspect my music preferences are similar, and I'm currently experimenting with full range speakers myself.
From my POV, if it's heavy material with huge LF dynamic swings etc., and we're talking 'ideals' then multiple sealed or EBS 15in - 18in HE woofers per channel with wide-band compression mids & tweeters, the mids covering as a minimum 500Hz - 4KHz. Active XOs, efficiency and headroom of all as high as possible without sacrificing everything else on its alter, potential for handling 120dB dynamic peaks at the listening position across the entire audio band.
You could also consider building Lotus' fraternal twin, Coniston. The EL70 will give at least the equivalent of doubling the amount of power you have on tap vrs the CHR-70
Dave, is this due to the increased efficiency of the EL70, the Coniston box, or both? The specs say only 1.5 dB difference between CHR70 and EL70. Maybe you have measured more difference than that?
Ian.
Quick question for Dave et al. If I were to use a stepped deflector at the base of my Coniston to add some additional mass, would it be possible to use MDF to construct this? (I vaguely remember the design sheet for a 'spawn' variant mentioning that you could use MDF for the stepped deflectors)
Ewan
Thanks for the reply Dave. I have already decided on slicing the top of the cabinet and using the standard deflector to remove some of the mass from the top.
With regards to a stepped deflector is there a rule of thumb for the layout of the stepped deflector in a Coniston or is it a case of getting the steps to follow the front edge of the angled deflector as closely as possible? I know on the spawn family i.e G Chang the sheets mention that the 'steps' begin half a material thickness back from the front and then each subsequent step is a material thickness shorter.
Ewan
How big the step is depends on the deflector angle... the above is for 45 degrees, attached for Coniston using 3/4".
dave
