Older Krell Schematics
Hi Benchtester and group,
I have a working Krell KSA200S and a second one in pieces that had a power supply failure. It has some blown power up relay series resistors. I also took the unit totally apart as I thought the output stage was blown but it turned out the transistors measured good. (That was sure a big waste of time!)
If I had a schematic maybe I could get the totally dismantled one working again. Especially since I have a working model to compare with.
Since I have not worked in now over a year and I don't need the amps (as my LME49811 amps are in my reference system now) I would sell both the working and non-working Krell KSA200S's if anyone really wants them for a good deal? But having a schematic to fix the blown unit would be great. With time on my hands fixing the bad one would be fun!
Also does anyone have any idea what a working or non-working KSA200S is worth?
Thanks,
Mark / audioman54
I have original Krell schematics, according to them the following models have the same buffer and voltage amplification stages and only the amount of output devices differ, KSA80, KMA160, KSA200 and KMA400. At a quick glance it seems the posted KSA100 is also the same.
Audioman54, drop me a mail with yours, these will be useful for your problem, they are complete schematics with power supply, relay board, soft start, oscilation sense, well the works, just promise not to try push those nasty sounding LM chips to me 😱🙄
I hope audioman54 has a thick skin and sense of humor.
I think he does, he s a regular guy, people take things too personally around here, but I m just being honest, I dont like the sound of those chips, although Im experimentig with the new AD4898 which I like and will be using to replace AD817 and AD829 which Ive being using for over 10 years in certain audio applications.
Anyway Ill give him a copy of the schematics if he needs them, I would place them here but I dont want Krell sending me any mail. 😀
La Mer,
The LME49811 power amp measures better and sounds better than the KSA200S and since one of my two KSA200S's died I would even say my proto unit is more reliable as it has been running full time for several years now in the same setup in my soundroom where the Krell died! But the output power (current) of the KSA200S is HUGE and it is a very good amplifier!
Mark / Audioman54
Where is the internal circuit of LME49811?
I don't find it about
http://cache.national.com/ds/LM/LME49811.pdf
By the ST power amp TDA7294V there is at least a basic circuit diagram at page 2/17 so as a circuit description at page 8/17 about
http://www.st.com/stonline/products/literature/ds/1057.pdf
Inner schematics of National parts not available
tiefbassuebertr,
National does not usually publish the actuall schematics of the inner circuits of new parts. Sometimes we did a block diagrams but in this case even the apps engineers did not get a complete schematic. Sorry. I wanted it also! I just know it measured better than anything else we "ever" had in the lab.
...And Homemodder have you been able to get those schmatics together for me? I want to see if I can fix the second KSA200S amplifier and then sell it.
Thanks,
Mark / audioman54
tiefbassuebertr,
Mark / audioman54
this brand new TI (formerly Burr-Brown) operational amplifier schows their functional schematic - go to
Precision Amplifier - Low Noise - OPA211 - TI.com
Very interest details
Regarded older Krell Schematics I have start this thread:
http://www.diyaudio.com/forums/soli...ter-reference-amplifier-schematic-wanted.html
