Mind made up
Yes I do.........
At the end of the day the NADs were there to play with. I pondered on how much I could improve them given the right bits 'n' bobs (although not expecting miracles) so I jumped in with the iron.
I've put quite a bit of time into them and it'd be a shame not to progress given they're coming on so nicely. It's pleasing to know I'm doing something different too, although it may be strange to others by starting with a 'budget' duo but I like them and at the end of the day, that's what it's all about.
On that note, I guess I've answered my own question.
Do you like your modified C515BEE's sound quality? That is the question.
Yes I do.........
My personal philosophy could be named "reasonable modding", meaning that you improve what would be reasonable to improve, rather than fitting expensive and complicated stuff in a audio component which is meant to be a compromised (between cost and performance) design in the first place.
Thus, I wouldn't use class-D regulators, special clock circuits, new toroidal transformers... as these things look overambitious to me. 🙂 I'm not saying that they won't do something good, I'm just pretending that reasonableness goes completely astray that way
as you can do simpler and far more cost-effective modifications that will refine the sound of the player without trying to make it into what it can never be - or you could've bought something better in the first place.
Yes, BTW, I've tried the complicated road myself before coming to these conclusions.
Thus, I wouldn't use class-D regulators, special clock circuits, new toroidal transformers... as these things look overambitious to me. 🙂 I'm not saying that they won't do something good, I'm just pretending that reasonableness goes completely astray that wayas you can do simpler and far more cost-effective modifications that will refine the sound of the player without trying to make it into what it can never be - or you could've bought something better in the first place.
I think you're missing my point completely.
I have many systems which fit in your 'better' category, including components from the likes of Meridian, Krell and Creek so I'm not interested in making the 'better' better.
The whole point as a newbie to DIY was to play around with something 'budget' and hopefully make it considerably 'better' whilst learning the ropes without having to compromise the likes of my more expensive equipment.
If you think it's 'unreasonable modding' in what I'm doing with my NADs then that's fair enough, but I disagree.
If you see it like that i.e. an 'accademic exercise', then I agree...
But that is not what budget audio components are for me... They're supposed to be long-term companions for lovers of music rather than hi-fi. If you mod them expensively like that (and I'm not saying you shouldn't mod them at all), you miss the whole point of buying budget-but-good equipment. But it's not your particular case.
Nice one Nad! I love the idea of taking a budget Hi-Fi component and making it competitive with higher-end equipment. Well done!
Thanks, I'm glad someone is happy for me. Seems if it's not 'high end' then it's snubbed.Nice one Nad! I love the idea of taking a budget Hi-Fi component and making it competitive with higher-end equipment. Well done!
Yep.
The thing is you can achieve a high-end sound with 'budget' gear if you mod it with care and attention to detail. Simply adding low noise supplies and substituting cap's can bring a big improvement. Care should be taken with component selection though. Simply throwing money at something (Blackgate/CARDAS etc) can often give poor results. Taking the time to try out several different cap types (and/or opamps) in different locations to achieve the right 'blend' is what proves fruitful in the end. It requires patience though.
One of the advantages we have in our hobby is that we can take an average product and improve it considerably with out spending a fortune!
Im on your side mate.
Put this way, I'm on your side too! 😎Yep.
Yep.
Thanks for that, my moral has increased 100 fold.
I actually like the NADs more than my other gear, whether it's to do with me putting the fingers in I don't know but they seem to be shouting 'GIVE ME MORE' and I can't help myself in doing so. Money isn't the factor here, I dont care if it ends up costing much more than I could buy better for, it's the 'I've done that' and the enjoyment of the modding that keeps me happy. Hopefully in the end I'll have turned something 'budget' into a cracker all by myself (and of course with a big help from diyaudio).
Back to the mods. tonight I added a bit of attenuation to the preamp. I added a 10k with a 6k8 bleed to try and reduce the brightness, it reduced that ok but it also reduced the bass considerably more.
I'm after 'less' brightness with no loss of dynamics, is this possible?????
Forgot to ask.............
Anyone out ther know of a much 'better' pin compatible D/A to replace the CS4392???
Try using tantalum caps for power rail decoupling. If you find them a little grainy at the top you can bypass with a small value film cap. Tants have good bass and dynamics by the way. Use AVX or similar good quality tants.
Got you with the caps but the 'bypass' is foreign to me being a newbie.......
I wish you lived in the states, I'd send you a couple OP trafos to fool around with.
Thanks, me too, it's a bit 'bob' here in blighty at the mo.
I'd probably mess it up anyhow, although if you are willing, I'd pay you for the bits and postage if you could guide me????
Lets say you use a 10uF Tant at the regulator output, the bypass cap would be a small value film cap - say 100nF - tacked under the board across the Tantalum. Usually the ideal value for a byapss cap is around 1% of the cap it bypassng. The film bypass cap will clean up the HF a bit. Works well with Tants as they have great bass and dynamics but a slightly grainy treble. The 100nF film (Wima MKS2 are good here) will clean it up.
EDIT: What are you using at the main output cap's? A cap too small in value will roll off the bass too early. Also applies to power supply caps. When upgrading I use the rule to either replace with the same value of go a little bigger.
A golden rule here:
Only ever make one change at a time. Listen and evaluate. Only proceed to make another change if you happy with the results of the one you just made.
Thanks, the main output caps are big Panasonic FC's. Brent from Audioupgrades did those so I'm assuming they're good?
A golden rule here:
That's my problem, I get the iron out and change alot at once.
- Digital Source
- My NAD C515BEE is finished.............
