Tda2030 vs lm1875
Yes LM1875.
If I have already tda2030a in my drawer or for low investor, tda2030a is good sound for the PRICE )
I will use four IC 1:Tweeter 2:Mid 3&4:Woofer (Bridge) i.e. 18x2+35 = 70Watts per channel. (Please Note that TDA2030A works as power op.amp.) & Same for another channel. It would be better option then 2.1. tda2030a sounds good with correct grounding & good 8 Ohms speaker mounted on floor standing enclosers.
Calculate the project cost :=
12-0-12 5A transformer = xxxxx.xx
tda2030a x 8 = xxxxx.xx
& required Component = xxxxx.xx
OR
LM1875 (off-course is a winner)
18-0-18 5a transformer = xxxxx.xx
LM1875 x 2 = xxxxx.xx
Passive crossover with expensive inductors & capacitors.
For above two project, my choice would be tda2030a. BUT if I have money then I would go with lm1875 tri-amp.
The LM1875 wins by far. I haven't looked at both datasheets, but the TDA2030 sounds way too compressed, has very poor dynamics. When I pulled it of the board and replaced it with the LM, the TDA ended in the trash bin.
U mean i have a 2.1 channel computer speakers. They cantain tda2030a and pt2353. Can i change tda2030a with lm1875???????????????????????????????????????????????????? with out any problem or distortion in sound???????/
Yes LM1875.
OR
plzzzzzzzzzzzz can u provide me best professional and 100% error free quality schematic for tda2030a single and bridge????/ and if pcblay out is there its wonderrrrrrrrrrrrr fulllllllllllllll? Thank u so much i like ur project. and i also wana make the same if u can provide me the best quality schematic. and plz tell me the speaker size for mid and tweeter i mean 8 ohm in 5 inch or 4 inch. and also size of woofer speaker?????????
I am not professional or expert member. I believe in DIY and that's a fun. 100% error free quality schematic is available in datasheet. STMicroelectronics's designer should be professional. And should not underestimate them. I am experienced member for tda2030a. Yet I will go following order.
1) Choose source (DVD Player) & Speakers
2) Build MONO tda2030a amplifier as per datasheet.
3) Listen & Listen.
4) I found sound vary speaker to speaker.
5) There is lot-off experiments for
---a) Input capacitor range from 0.01uf to 2.2uf
---b) Gain: 20 for tweeter & Mid, 32 to 47 is for woofer.
---c) As per datasheet page # 2 : C2 can be use 10uf to 47uf or more. But switching noise affects.
---d) Classic grounding. (Lot-off threads here)
---e) Good schematic is on page # 10.
6) Input crossover you can choose after listening your source several times.
I can post my schematic which is good for me.
3) Listen & Listen.
I am waiting for your schematic.
