Next Zen designs
IXYS vs IRF
The curiosity got the better of me.
Here is a zen circuit using IRFP240 and IXYS linear device
Top of the screen is IRFP240
Bottom of screen is IXYS Linear Mosfet (Enhancement Mode)
Such speculation. I have a number of new JFETs and
MOSFETs, some enhancement, some depletion. All high
voltage and power.
Realistically, the winner will be the one with the lowest
distortion in a simple circuit.
I'm going hedge my bet then, if it's not a power JFET, it's a MOSFET that looks and behaves like a JFET 😀
hmmmm, now I'm even more curious.
If it's not a simple case of swapping in and out different devices then we must have different devices wearing different hats. A power JFET below and something different for the current load ?
Or an attempt to go a step further than your 'sweet spot' article, combining two devices with different characteristics to achieve a 'super sweet spot' perhaps ?
It's not generally a case of simply dropping new devices into
a given circuit, although that is often an indicator.
The "sweet spot" is always looked for, but I have never seen
a "super sweet spot". While conceptually possible, it is
unlikely, as once you get second harmonic cancellation all
the low hanging fruit are gone.
well the zen 'papers' are still fresh for me, having only discovered them a month ago so it will be very nice to see the next chapter 🙂
If the concept of simplicity remains there can't be too many options to use up different devices here - input buffer, single stage amplifier, active load, and power supply (cap multiplier)
talking of 2nd harmonic removal... a zen-like symmetrical push-pull ? no it has to be SE !
