Morel voice coil replacements / new "CAT" tweeters...
I just got one each of the CAT 308 and CAT 298 tweeters at the PE tent sale. I'd never tried Morel tweeters and was curious to do so. They do seem a little expensive though. (overpriced?) I do like the solid aluminum face plate compared to the flimsy plastic face plates of some tweeters.
I was wondering how interchangeable the various replacement voice coil/diaphragm assemblies are on amongst the various Morel tweeters. For instance, might I be able to put this:
On either my CAT 308 or 298 magnet assemblies?
I've seen various posts where people switch diaphragms, but so far, only w/Seas tweeters, such as the DXT (similar sized horn as the Morel).
My main desire for using the horn is time alignment.
EDIT: Oh ~ and, does anyone know what other cheaper brand of tweeter might be compatible with the Morel voice coil assemblies?
The one remarkable feature that most of the Morel tweeters seem to have is high power handling, if the published numbers are accurate? They claim very low compression at high power levels. Some individuals comments seem to reflect this.
I got one of those "replacement voice coils" which comes with the waveguide faceplate and it does indeed fit on both of the different Morel magnet (motor) assemblies I have. And, it comes with the screws that you need to attach it, which is particularly nice since the screws for the other face plates aren't long enough.
That looks like a DMS 37 semi horn loaded face plate. The DMS 37's are what I'm using (for time alignment reasons also) It was designed by the Morel Aust distributor (who uses their drivers exclusively in his own high end loudspeaker designs) so that when flush mounted it was time aligned with the 5" MW-144 if it was surface mounted (or so he told me).
I have yet to do any measurements to verify this. Whilst the magnet assemblies might be physically compatible, whether or not an old version tweeter such as the DMS 37 has the same magnet construction as a new tweeter is probably something you should consider... Not sure if the specs give info on the motors, but if they do and they don't sound the same it might not be a good idea to mix and match 🙂
Tony.
I can answer some of your questions and make an educated guess on others, though as Tony says, one can't be sure about the newest labeled versions.
I bought a couple of these a while ago as replacement attempts on the original MDT-30 driver (motor should match the 30s). I had previously bought MDT-32 replacements. This required prying off the solder mounts that are attached to the faceplate. This can be done, but you must take care not to get any metal shavings in the gap. I found that using after prying up the cardboard-like sides that I could then finish prying it off with pliers.
The MDT-37 replacement then fits right on as Tony said. I measured it on a PE baffle that doesn't has a larger cutout than required, but with felt over it, the result is excellent. I'll measure it on my 2mx2m baffle, just don't know when. I may try this weekend.
It will also fit the Parts Express "Silkie", the original versions I, II and III. I have a page at my site that shows a number of hybrids, the MDT-32 attached to a PE motor that is effectively an MDT-32, only without a real chamber. The MDT-37 attached to one of these ought to be a good combo. This would make for an el-cheapo version the MDT-37. It does need the pole-piece stuffing (lamb's wool or cotton) and should have a felt or cotton ring on the pole-piece top, but it's doable and not expensive.
I don't know if it will fit the newer DC28F (aka Silkie Gen IV), but the motor looks like the earlier Silkies. The advantage of the Silkies is that there is no voice coil solder mount to remove as there is in the MDT-30. The MDT-32, of course, has none either, but in that case you have the cost of the Morel motor. With a PE motor and Morel diaphragm assembly, you get nearly the same driver at much less cost. Morel did not change the basic motor for years apparently. I haven't seen a CAT308, but I'd lay money on the motor being the same.
That's not unusual. Vifa used the same tweeter motor across their entire line for years. Many of the D25/D26/D27 tweeters all used the same basic motor. Seas does this as well from the few I've seen. There are no cross-fitting substitutes for these, though. No cheap motors accept their diaphragm assemblies that I've seen.
Dave
Hey Dave, I'm not sure why I didn't try mounting it on the DC28F - I vaguely remember that I noticed some mounting issue with the stamped pattern on the front motor plate on the DC28F I have... The ones I have I bought about a year ago, I'll have to see if it [the Morel 37 rep. dome] fits when I get home. If it does, I'll have to pickup a couple more.
Too bad it doesn't fit the nicer motor assembly of the RS28.
If it does fit the DC28F motor I'll have to take some measurements, and, see what woofers I can get time alignment with that setup... A friend of mine at a speaker company refuses to sell any new speaker designs that aren't time aligned after they did some listening tests with time aligned vs non-time aligned speakers.
There are few drivers/diaphragms that can be used with mixed manufacturers. The only other one with which I've had success is a hybrid Scan-Speak D2010 and Hiquphon. That takes some real work due to both being hermetically sealed and with a very tiny dimension issue with the top plate. It takes destruction of one due to no supply for replacement diaphragms.
Is he actually referring to a time-aligned system that is also a transient-perfect one? My suspicion is that he's actually referring to (nearly) aligned acoustic centers that improves phase tracking and keeps the lobe forward if an L-R type. Being time-aligned doesn't really mean much for a non-T-P type system. Phase tracking and lobe axis are far more influential. Time-aligned without phase tracking is something of a win/lose situation.
Dave
He uses an old oscilloscope like device with both impulse clicks and square waves. With both the woofer + tweeter wired in phase he moves the tweeter physically back & forth to align the impulse and also to try to get a decent but maybe not perfect, square wave. Sorry I can't disclose the type of crossover that he uses though.
It is a mystery what the factors are that make me dislike most speakers I've auditioned, so, I'm always thinking about things like time alignment, transient perfect, etc... Hoping to find a speaker that I find emotionally engaging again, that I find pleasant to listen to for more than a few minutes (without spending tons of money). I suppose it's ironic that I've bought so many different "buyout" and other various drivers that I've easily spent more than it would have cost to buy a couple pairs of high end woofers + tweeters.
If the measured response can actually approximate a square wave, it sounds like he may have some sort of T-P crossover. Could even be simple a first order Butterworth for that matter, the type Dunlavy used, but it also sounds like a 2-way and other than BW1 there aren't many other options for a T-P system. If it's not a T-P system, the phase alignment is the key issue. Adjusting with that method probably emphasizes phase. Time can be identical, but if the individual target responses aren't met due to driver issues at their extremes, response may actually suffer.
The adjustment he's making most likely is not a perfectly time-aligned system, but one that is a compromise between time and phase alignment. This would be the best practical system, since most drivers have issues at both ends that affect phase in their bandpass.
Most DIYers seem to want to put the best of this with the best of that. They fail to realise that what they are doing is to try and marry this mid to this tweeter. How the individual drivers perform is a small part to consider. The larger question should be how will my drivers marry. If they marry perfectly then and only then will you get a top class system. The DMS37 rebate mounted with the MW142/144 surface mounted are a near perfect match. So perfect that when you design the crossover you will be in for a surprise. I did up a nice 1st order xover, put in a whole lot of components and when measuring and listening I started taking out components. In the end I had one high grade cap left (5.6uf from memory) and the woofer was just taking it's feed straight from the amp. These two drivers just love each other. The relationship is much more important than the individual drivers.
Terry
Hey Terry straight from the horses mouth! 🙂 I didn't think you frequented the forums! I just checked your profile and found you are the person I alluded to in my previous post in this thread 😉
I can't believe it is nearly six years since I first contacted you about the morel drivers! I'm going to get there eventually... Was starting to gain momentum again but have hit a wall for a little while, hopefully in a month or two will be back into it and get these things finished! and start enjoying them!
Tony.
edit: Nice to know when I did my prototype that I wasn't going crazy when I thought it sounded brilliant with just a cap on the tweeter and the mw144's running full range too! 🙂
Tony.
Thanks Tony, these combinations are rare. When you find one, enjoy. I am now designing a 3 way using these two as the mid / tweeter. Bass may be Morel.s Neolin 222mm (8")
Terry
Terry
To each his own. I would never run any midwoofer without a lowpass, breakup is an issue in any driver as is directionality at the upper end, especially in the breakup area. I also beg to differ on the individual driver response. That is crucial to making any design choices. You can't know how they'll "marry" without knowing how they act individually.
"Most" DIYers are not as you assume. Matching drivers is, in fact, generally high on their list in my experience, as is mine. Wanting the best or best bang-for-the-buck combination, yes, but not blindly selecting as you imply. I'm not sure why you even injected that into the discussion.
That aside, that system has to be something on the order of a 2nd order lowpass (or whatever the native driver has) using the midwoofer's lowpass and an approximate 3rd order highpass by adding a cap to the tweeter's 2nd order natural highpass. That type of system is not going to pass square waves without distorting them, but then I'm not usually doing transient-perfect designs myself, preferring LR2 in general. Looking at the quasi-IEC measurement, how is baffle step taken into account? With a fairly flat driver as that one appears to be, there's no getting around the step loss unless it's used in a 3-way with a highpass that handles it. In a 2-way, it's going to lose 6db before any boundary reinforcment comes into play. Even then, 3-4 db correction would not be unusual.
It would appear that my comment about adjusting for phase was accurate, since it's not a crossover type for which time is as critical. Phase is the issue, especially with the woofer lowpass not being controlled in any way with its impact on the passband phase.
The native lowpass looks to be down 3db at 10K, so I'm unsure as to what is being used for the highpass Fc. 10K would be exceedingly high, but would be what is indicated by the Morel graphs. 5.6 uF isn't going to result in a very high tweeter Fc, however, so it seems like there must be a lot of overlap and possibly a fair amount of destructive interference.
Dave
:spin:
Dave
I will certainly agree to disagree. 😀 No problem. I like first order crossovers. Yes I have lots of experience at other orders. You like yours, I like mine.
A well executed design using first orders, with the right drivers in a point source array has lots of benefits. There are many very famous speakers using this approach. Duntech used this approach with great response and great sales.
Terry
The only speaker I've ever heard that fooled me into thinking a real live trumpet was playing in front of me was a custom built wide range single driver fully omni-directional prototype speaker.
When I first put on a Miles Davis track I nearly jumped out of my skin. But, without a crossover and without a tweeter, and without a subwoofer, that speaker was somewhat of a one-trick-pony.
DLR - he does actual time alignment first, with only a cap on the tweeter for protection. Once he has time alignment, then he starts designing the crossover.
Terry, I'm always wanting to hear more speakers with "just a cap on the tweeter", but, my favorite commecial speakers that I've heard in the last 10 years or so were the Madrigal Revel Salon Ultimas. I don't think any of the DIY speakers I've heard at events compare to them, but, I can't fairly say, because I haven't liked the listening conditions at the DIY events I've seen thus far. I would like to attend some smaller gatherings and "just listen to speakers" with a few guys sometime soon. I was invited to such a gathering last month or so, but my second child was coming at about the same time so I couldn't go.
I'm sure that was a wise choice! Not supposed to miss the actual birth day. I agree that the listening environment is so important! I've designed a great many speakers some with great sales. For my own pleasure I like point source.
Terry
:spin:
Terry
With all due respect, what you have done with running a midwoofer full range and a cap on a tweeter bears no resemblance to anything Dunlavy did at Duntech or later and is in no a way a first order system. Dunlavy's were true first order system responses, yours cannot be. The electrical characteristics of the crossover do not in any way define the acoustic system response.
I'll also point out, for those who do not understand, running a flat midwoofer with no crossover results in a large step loss when stand mounted (6db before boundary reinforcement) that then emphasizes the upper midrange andtreble. This emphasis is to some preferred, to many and I would venture to say most, it would not be.
But again, to each his own.
Dave
Dave
Dave, I don't need to convince you. Continue with what you like in xovers. I like discussions. I hate when people knock others with out understanding what they themselves are saying.
Terry
Terry
You don't need to convince me, you won't if what you say is incorrect, but you should be cognizant that others read these posts. Your statements equating your design to those of Dunlavy were not just wrong, they mislead others who might accept them as factual. You want to discuss, let's discuss. Explain how you think that a full range midwoofer with a 2nd order or higher acoustic lowpass and a tweeter with a 2nd order highpass and a cap that results in a third order acoustic highpass equates to the works of Dunlavy who went to great lengths to achieve well integrated first order acoustic responses.
Point out what I've said that is wrong, discuss it, don't make claims of what I may or may not know when you have no idea of what I may or may not know. Refute with facts, not supposition. A simple set of two measurements, woofer and tweeter, is generally sufficient.
This started off as a simple thread on a good idea of a DIY version of an MDT-37 and has morphed not due to my inserting claims that so far are unsupported by facts. Either you can back up your claims or you can't, I leave that to you. But I will challenge when I see what I believe to be erroneous claims.
Dave
Ok Dave,
"You can't know how they'll "marry" without knowing how they act individually".
When looking at how they Marry you need to consider what one does to the other. Yes you need to look at their individual operation but only as it affects the other driver. The relationship is important, not how good an individual driver is perceived to be.
"and an approximate 3rd order highpass by adding a cap to the tweeter's 2nd order natural highpass." " 5.6 uF isn't going to result in a very high tweeter Fc,"
Actually it is 6000 Hz. For the entire xover region this tweeter is 1st order. It is not 3rd order as you state.
"however, so it seems like there must be a lot of overlap and possibly a fair amount of destructive interference."
Why are you assuming it is destructive interference?
I stated quite clearly
"Thanks Tony, these combinations are rare. When you find one, enjoy."
You have taken no notice of this quite clear statement. You hav'nt tried it, you have not listened to it, you just come out of the gate at full steam. You don't like 1st order! That's fine. Enjoy what you like. Be careful not to set yourself up as an expert in an area where clearly you don't have experience.
You also have not clearly understood that this system is time aligned.
"That aside, that system has to be something on the order of a 2nd order lowpass (or whatever the native driver has) using the midwoofer's lowpass and an approximate 3rd order highpass by adding a cap to the tweeter's 2nd order natural highpass. That type of system is not going to pass square waves without distorting them,"
How do you know what this system will do. Try it. Remember it is rare to find two drivers that will do this.
FYI I did consulting work for Duntech after Dunleavey sold the company. I know their designs.
Enough, A question, have you ever designed a system based on 1st order.
Terry
EDIT: Dave was replying as I wrote this, looks like my post wasn't needed, I think the discussion is back on track, after almost getting derailed (perhaps).
Let me just take a moment to suppose that... Had you two been sitting in the same room together discussing these topics, I for one, would be willing to bet that there would have been no insults felt or implied - at least not to the point where anyone would feel one's "feathers ruffled"...
So, let me ask, do please continue your discussion about "first order" crossovers, just... pick up a little Zen attitude and even if "he started it first" be the bigger man, and graciously dismiss any insult that may have been meant, or not. Any questions or implications that may have implied insult - let's take them as if they hadn't, and simply respond sincerely.
I'm not saying anybody has been childish here - I just see an opportunity to further a discussion, rather than one person or the other maybe feeling that its headed down a negative path that will end up without much merit.
"Two roads diverged in a wood, and I—
I took the one less traveled by,..."
