Group Buy: DRV134 pcb, unbalanced to balanced
Hi Peranders,
Is there kits available for the DRV134 pcb's now. I'm confused at first you said there wouldn't be any but now it seems there are.😕
If there is can you change my WiKi to add the kits with my order. Just paypal me the difference.😀
Also one question, the rectifier is on board already, how much voltage is needed to run the DRV134 unit. Can I splice it from the big transformer (BPA300)
Thanks for your help... JohnnyP00
I have been gone for a long time, and havnt followed this forum much. I was without a computer. Peranders do you need the dale SMD power resistors? I have a reel left, and have donated to all the group buys before. please let me know in forum or email. Than you for your help with the previous group buy also.
P-A, the note says:
X2 shall be GND -OUT. It is this way on the board already, apparently.
X3 shall be GND +OUT. This seems wrong, as the second terminal (from left) is connected to the ground plane.
WRT X2 and X3, the outer terminals are connected to ground plane.
