Help with B1 PSU
I have replaced R1 and R2 with 5.6R 1w resistors. Both the caps are changed to 220uF. While waiting, I hook up the transformer:
a) the output is 05.83v (img 'output after change R1 and R2')?
b) R2 referenced to Gnd = 35.76v
c) R3 refernced to Gnd = 35.63v
d) voltage accross R3 = 6.53v
Did I burned something?
The zener voltage you should choose to be around the output voltage that you want. To test with the zener, take out R8 and R9.
It looks like too much current is being drawn now. Is it still the 470R load?
Please use a load for testing. What is the exact voltage that you want at the output? Then I can give you better advice.
24v and the schematic you gave is the correct output.
I have changed Q2 and added in a 470R 1w resistor. It goes from the output and connect to the 0. The output is 3.6v.
voltage across R1 = ~0.213
voltage across R2 = ~0.013v
across R3 = 0.651
OK the, the 2sb716 will not work with my previous schematic because it can't deal with so much current. Here I adapted the schematic to your situation. This one you can use for testing.
For this, use a 1k2 1/2W resistor as load.
If you really wanted a regulator that shines with B1, have a look at the salas v1 regulator that he uses in the direct coupled B1. You'll only need the positive side of it, and change the zener to give you higher voltage. That regulator will outperform this one in every respect.
I'm not saying you should not fix this one, you should, and then build the other one, and compare them. You will not be sorry. :up:
I have put my name for a couple of his boards at the Group Buy. Should I use the salas v1 regulator and forget about this one?
I changed the Q2, now the output with the 470R 1w is 9.20v and without load is 18.70v.
voltage across R3 = 0.651v
I do not have the caps and zeners with me. Need to source tomorrow. I'll like to thank you and Andrew very much for helping. I appreciate it. Maybe I'll just use Salas's scheme.
Better spend time on a better regulator then. There's risks in Salas's B1 as I note in his thread. It is late over here in KL.
The risk is with DCB1. If you want just a regular B1, then all you need is the positive salas v1 shunt reg.
BTW, I found what your problem is in your current regulator. Replace R9 with a 3k3 resistor and you will get around 25V out without a load. If the voltage stays the same with a load of 1k2 or 1k4, then it works fine.
The TL431 in your original circuit is setup for an output of about 18.3V.
You are a great man. Thanks. I'll get those resistors tomorrow morn. I was searching through the 'Building a symmetrical psu B1 buffer' thread. I should have look at this earlier but 2sk170 is hard to find.
Should I wired both the 24v wires together?
No, that would probably short the transformer!!
what was going through my head when I posted was that it looked like a centre tapped transformer, rather that a transformer with two separate 24V windings... If that is the case then the voltage between either of the two outside wires and the centre wire should be around 12V AC (assuming good transformer regulation)... If you factor in poor transformer regulation this could be a quite a bit higher, and the recitified voltage would be probably around the 18V mark which seemed to be what you were getting.
If indeed the transformer is a CT unit, then there should be 24V between the two outside wires, and it should measure around 12V for either side to the centre wire. whilst the printing on the top shows 24V on either side and zero volts in the middle, I'd be checking it to see if it is really the case 😉
I probably should have read all the posts (or not posted at all under the influence of alcohol) , as I now see you did have readings higher than 18V and I've probably only succeeded in confusing the issue.
Tony.
