new Beyma 6.5" coaxial
Hello all!
There is a new small Beyma coaxial that aims more at wide frequency range than on high sensitivity and so is suitable for compact hifi solutions.
http://profesional.beyma.com/ingles/pdf/6CX200Nd_tec.pdf
The 65 Hz Fs and the strong motor seemed to be ideal for a ML-pipe, so I did a simulation with an old MJK sheet. Cross-section over the whole length was 2xSd, length 132 cm (quarter wavelength of Fs), port dimensions didn´t seem so critical.
Looks like a true fullrange solution, and that with a high-WAF slim coloumn.
Opinions?
I've made a pair of prototypes:
After x-over and eq and stuffed port
Step resp
on-off/axis
Slopes
Glorified Hi-Fi curve :smash:
Retail price is 220 EURO.
Sound is excellent. Amazing low end respons. It's a bit tricky to get flat and smooth sounding. But Beyma's original curve's are pretty fair.
Highly recommended :umbrella:
I'd be more interested in seeing the curves without the EQ, and without a brickwall digital filter....
Are there any information about how you get that bas response out of that driver.
Transmission-line, vented or … ?
Cabinet info, please. 🙂
Manger
Sorry for the OT:, but...
Charles, I hope you haven't given up on the Manger! If so - why? (Have several drivers that have good low-end response extending up to 500 Hz. or even 1kHz., so if it's the low/mid response of the Manger - I can simply cross at 200 - 500 Hz., using steep linear-phase slopes).
much thanks,
-Tal
I recently started using its larger brother the 8cx300nd and I can assure that it sounds very fine after some equing.
Charles
Step resp
on-off/axis
Slopes
I'm highly interested in building a pair of these to me! Could you please share the details of how many liters the enclosure has and the dimensions of the air duct? Thanks buddy! 😉
