FS: DIR9001 to CS8412 converter board
Spencer or anyone else,
I replaced the CS8414 in a DAC (CS4329) with this DIR9001 board. When I connect my digital source the output of the DAC is heavily distorted. I can get the distortion to go away by lowering the source level by around 8dB.
Why does the source need attenuated when using the DIR9001? Does it have anything to do with the CS4319 being 20-bit and my source being 24-bit?
Hi there............
I purchased one of these boards last Spring- and I now want to install it in my GCD-750 which uses the CS-8412.
I have attached a schematic.
Can anybody tell me whether or not I can do this before I go hacking into my player??
What settings do I need for the jumpers??
  • gcd5ssp.pdf
See details of the converter board here.
http://www.fetaudio.com/?p=176
Since it is not 100% fully compatible, you need to ensure you can handle the modification before you want to buy this. Of course I also heard of many success stories in the past.
Only assembly board is available now as I encounter some has problem in soldering the kits.
Price is $29 including shipping and paypal charges to worldwide.
Spencer
