Schematic for a small SE EL84 amp
- By RMS
- Tubes / Valves
- 54 Replies
I have a 269JX Hammond PT, only has 60mA so I wanted to build a amp with one pre-amp tube in the 12AX7 family and one EL84 hooked up in Class A, SE.
Has anyone come accross a schematic like this that I can copy?
Also I am fairly new to the audio world using tubes and I have a few questions :
Because of the pre-amp tube does that make this amp intergrated?
Why is the volume pot located just after the RCA jack input and not after a pre-amp stage?
I have built tube guitar amps before and these audio amps look so darn close to each other what would you say the difference is?
Thanks!
Thanks!
