Custom tube torroid order calculation check please
Just looking for a critique/common sense check for the custom toroidal order I want to submit later this week. Sorry for the amount of info but it's complex hence asking for help.
Future requirement - to be able to use this transformer to test prototype modules for a later amp using tube based opamps etc. However for now this is V1:
V1 Amp requirements - this is the amp's requirements.
+320V at the B+ rail, 120mA total (per ch: 20mA max for cascode, 2x20mA for drivers)
-320V at the B- rail, 40mA total (per ch: 20mA for cascode only, drivers are to ground)
+200V at the output B+ rail, 480mA (per ch: 4x60mA)
-200V at the output B- rail, 480mA (per ch: 4z60mA)
Each supply will ultimately have a 9H choke then a maida regulator. I will find out the choke resistance but for now I'm using spec for a 9H toroidy choke (29ohm) and then putting ~30V drop for the maida. The supply is full wave rectified hence 1.414 voltage increase and I'm making an assumption of 0.60 current drop.
Thus the power supply requirement for the 320V rails at 160mA:
320 + 30 + (0.16*29) = 355V, then /1.414 = 251V voltage from the secondary.
160mA / 0.60 = 266mA required from the secondary.
Thus ~ 215*0.266 = ~ 60VA minimum
For the power supply for the 200V rails at 480mA:
200 + 30 + (0.48*29) = 244V, then /1.414 = 172V voltage from the secondary
480mA / 0.60 = 800mA required from the secondary.
Thus 172*0.8 = ~140VA minimum
Heater requirements
12.6V Heater referenced to +50V, 3.4A total from the following:
* 2x 3x300mA
* 2x 2x400mA
12.6V Heater referenced to -150V, 2.4A total from the following:
* 2x 1x300mA
* 2x 2x400mA
This will be regulated DC, again this will likely be a RC (5ohm) with a maida (10V drop configured), full wave rectified. Just taking the larger current at 3.4A:
12.6V + 10V + 3.4*5 = 40V, then /1.414 = 28.2V or 30V
3.4A / 0.60 = 5.7A
30 * 5.7 = 171VA
So anything I may have forgotten (perhaps 2-3V for the diode drop?) or observations?
I'd like to finalise the order later this week.
FS: Heathkit IG-18, EU good condition
I want to sell a Heathkit IG-18 i got for a project that I do not have time to even start.
It is good overall condition, perfectly working and as far as I can tell, in spec. Inside, everything is original, very clean and all switches are in great condition - again as far as I can tell. This is no collector's item, it is a working device with a bit of scruffs and repainted covers (not by me); only missing the black plastic side handles - see pictures (which were purely aesthetic IMHO...) and two banana post thumbcovers, otherwise absolutely complete.
The electronics inside are all OK, when I got it I checked the electrolithics and they were OK, I just replaced a small one that was going south.
Front plate is very nice, and it still has the original power cord - whoever gets this, replace the cord!
Wired originally for 220/240V.
I am also including a PCB to build the IG-18SL, a complete rebuild of the Heathkit oscillator using the HP339 schematic, pioneered by Steve Lafferty. I am also including a pic of a built board inside another IG-18. Details of the build are available on Tronola.com.
Asking 70 Euro plus shipping.
SOLD, thank you everyone. It's in a tube amp builder's home now!
Cost-no-object headamp / preamp
Hello to one and all,
I am a new member and a total noob with minimal soldering skills who would like to build a headamp / preamp, preferably with 2*6SN7, 2*300B, 1 or 2*274B, as well as XLR input / output.
Is it gonna be very difficult?
What is the complete list of components out there that I need to buy? (finest quality possible)
Also any schematics available?
Cheers everyone!
Amplifier repair
Hello all,
I recently picked up a blown MTX 2300x strictly for a learning project as I have taken a recent interest in amplifier design. I am still quite new to this, so please bear with me...
The original owner was hooking up a capacitor when the amp blew.
I hooked up the amp on my bench with no input, and no speakers hooked up and read 44VDC across the left channel. It would read 44VDC for 2-3 seconds, drop to 0V for about 1 second, then continue repeating the cycle.
I took the amp apart and found one shorted fet on the left channel.
I removed the 4 fets in that group (center row, top) and tested the amp again (is this a bad idea?)
Now with the fets removed on the left channel I powered up the amp to see if there was any output on the right channel. It was very weak and severly distorted, could this be due to the fact the fets on the left channel are removed?
Also, the fan does not start for some reason, before I removed the fets the fan worked, but was super noisy. I am not sure if it is activatedy by a rise in temp. or not.
I am going to remove the rest of the fets tonight and test for shorts.
Are there any other tests I can perform on the amp before I solder in some new parts? I dont want to replace them all again. Anything else I can test while I have it apart?
Thanks for any help.
FS: Hana SL with active MC preamp
USD450 Hana SL with MC headamp compatible with phono MM input.
The cart was purchased May 2020, played couple of hours every week and put on storage after a year.
Sl with shibata stylus should last 2000 hours
Review: The Shibata Syndrome – Hana SL, a killer sub-$1,000 cartridge | Part-Time Audiophile
MC headamp is based on Richard Lee's MC-pre circuit, with ZTX851/951 pair, Panasonic FM, Nichicon KZ MUSE capacitors and Takman REY resistors, much quieter than SUT.
Two D cells last for whole year in always on state.
https://www.lencoheaven.net/forum/index.php?topic=35960.0
Richard Lee’s Ultra-Low Noise MC Head Amp
Heathkit Guitar amp tremolo capacitors
Hello,
I have a Heathkit guitar amp with a tremolo working intermittently. The optocoupler is working as of now, and Ive replaced all the electrolytic capacitors. I am not getting the voltages, indicated on the schematics, to the transistors, so I took out the 3 0.22uf capacitors to check them. 2 of them broke when I did, so I am going to replace them.
The ones in there are 250V. Would a 100V replacement be ok? Or 0.1uf? These are options I have on hand.
http://ctgelectronics.weebly.com/uploads/3/1/6/6/3166248/6483742_orig.png
A strange (for me) Turnberry story, any idea ?
Dear friends,
First of all I apologize in advance for any possible forum rules violations of mine. This is my first post!
This is a strange story (maybe not so strange for people more expert than me) I would like to get Your comments about.
During the ‘strong’ phase of the pandemy one of my old AR91’s died and wanting to give myself a present in that sad situation, given the plenty of good reviews on the net, I took the risk of buying a pair of used Turnberry SEs without listening to them before.
They arrived like-new in their original packages, not even waxed, no sign of use/intrusion!
I connected to my amp and listened … terrible! A dull, boomy, muddy sound I could only slightly improve with the help of a good 5 bands parametric EQ.
I am old but my doctor says I just have a slight loss from 5 Khz. Other younger people listened to the speakers and had the same sensation. I tried different positions, rooms, amplifiers (SS, PP Tube, Class A ss) ….. no improvement!
After 2 months of readings and tests I disconnected the tweeter’s plug and paralleled the medium bass with a couple of ‘poor’ (but stylish) Grundig ‘satellites’ from the 70’s I had just restored. They have a nominal 400 to 20.000 Hz range.
The sound immediately opened, even with the limits of such drivers.
Next I connected the Tannoy’s high freq. driver with a handwired copy of the original Tannoy filter (a simple RC cell) and fed it with a 1 Khz, 1 Vpp sine signal from my generator.
I got only a very very feeble output. Same behaviour for both drivers (left and right). I also checked the Tannoy filter cap (2.2 uF film), capacity is ok, ESR near 0.
In desperation (Tannoy driver burnt?) I started paralleling the Tannoy RC cell cap with some bipolars I have, increasing the resulting value. As far as I know this should lower the cut frequency of the cell.
With 6.6 uF total capacity vs. the original 2.2 uF I mounted back the drivers in their cases.
…… The sound is, let’s say, 10 times better than before, voice is clear, highs are brilliant. Even if the general impressioni is obviously of some unbalance, I perceive the general quality of this loudspeaker. I am now starting to test different cap values to find the best compromise. My Eq will could the rest I hope.
Some of You can explain ? Burnt drivers should give, I think, more serious symptoms than low output level. The 2.2 RC cell cap seems to be the standard for Tannoy Turnberries. Both loudspeakers behave the same way. Maybe this was an experimental series of Tannoy drivers ? a market-specific configuration? what can be reasons for such a defective (for me but not only for me) behaviour ?
Thanks for Your kind suggestions and opinions
Manlio
Circular Flare in Plywood.
Having had the recent fortune to obtain a good pile of 3/4 furniture grade plywood, I began construction of MJK's 18" H frames and the two 20" square OB baffle boards that sit on top.
I'm not a very good furniture maker and can eek out a "C" grade cob-struction at best. I shoot myself in the foot at least a few times during any such project, which adds hours onto the task to correct.
This time I cut the rear chamfer flare for my 4" MarkAudio Pluvia 7 HD speakers on the wrong side of the baffle board. Cut it on both before realizing. As I was so lucky that the pile yielded enough for two H frames plus two 20 X 20" baffles, I cant just flip them and use the backside...
It's salvageable. However it occurred to me that I could turn the mis-sided flare into a short circular waveguide - I've seen them where folks mount a driver front flange against the back of the baffle, letting the driver project through the baffle and flare. This would leave the back of the driver wide open for OB purposes.
I have no idea how to do this on a 4" round hole, offset in a 20" square board. Except file and sandpaper away, until it looks about right. The only tool I have which might help is a Craftsman table router, where I suppose I could remove the fence, get a bead bit with the bearing on the end and chase the somewhat square edge of the somewhat circlular cutout. Sounds like a disaster...
Maybe I'm better off just mounting the speaker however I can; there's enough material for the screws to sink into if I dont flare the back side too wildly - or at all.
1. Would a circular flare of unknown "looks about right" shape ruin the sound of the Pluvia HD, when mounted to the back of the baffle?
2. Should I bother to flare the backside, risk losing the two pieces for mounting the PHDs? I can still cut 8" holes and run a set of Visaton BG 20s I have.
3. I have enough wood stock that I could enlarge the holes to, say, 6" and put the drivers on a suprabaffle. My mistake doubles the effort...
Thanks for any insight you'd care to share.
Guitar amp using only 6F12P (6Ф12П) valves - can it be done?
Hi everyone,
I built an AC15-style amp last year. It was my first attempt at making something with valves in it and it sounds pretty good. I have an idea for a second build, but my knowledge of some of the theory behind this stuff is still patchy at best 😀 So with that in mind, I throw this idea out there to the forum in the hope that someone might very kindly sense-check it before I start buying parts etc..
Is it possible to build a low-wattage guitar amp using only 3x 6F12P (6Ф12П) valves?
The 6F12P is a split triode/pentode valve in a single envelope, with the pentode section having a max dissipation of 5 watts @ 330ma heater current.
I'm thinking you could use 2 of the pentode sections as a push-pull output stage, with the 2 triode sections joined together to form the phase inverter (LTP). If that works, you get a PI and output stage for only 660ma heater current. I'm guessing here... but I'd hope you could get something like 7 watts output from it (cathode biased)?
The third 6F12P would be the input stage. You could use the pentode section as the first gain stage, a bit like the old EF86-based Vox circuits. The remaining triode could drive a tone-stack or maybe act as a gain boost.
Worth trying? Or doomed to failure?
Vintage 3Watt Tube
Hello Solder slingers
I have a 3 Watt single-ended power amplifier made by Packard/Bell. It was scavenged from a small console stereo. I no longer have the preamp section or the speakers. But as a stand-alone amp using EL84 tubes it can power a full range pair of speakers. I'd like to turn this into a HeadPhone amp with volume control and a single input! I know very little about amplifiers, but I thought some guidance could be found here in Tubes and Valves. I do have a schematic someplace from a long-ago curiosity search. Help, suggestions, directions?
Thanks, kingfisher
Sherwood AD-2220 CP Please Help!!
Hi guys i have some real troubling problems with my sherwood amp, other than its 100 years old and cant afford a schematic .. i realy need 2 photos / resistor codes if someone could help me out that would be soo greatly appreciated.
i need a good quality photo of the protection board ( it has a 5112100 stamp on it its small & square, fits in your palm the other is onthe left side of the power supply (right near the relay) there is a couple of little green resistors i need to see the codes for they, same with the protect board i'll note their names
i would love to hear this amplifier, the only way that will happen is if i can repair it, i have no problem fixing things but the resistors are completely fried and i cant read their bands! please help!!
the codes are (POWER/AMP BOARD) R401R & R401L (Their located near the 2 10 ohm 2 watt resistors (grey colour risen off the board)
and R329R & R329L (PROTECT BOARD)
I have replaced the 2 left and right R330 resistors with 1 watt resistors, even if someone has a service manual i would realy love if i could have some help please please helpp!!
Options for bass in dipole system
I'm looking into adding two subs, maybe sealed or H-frame OB, and maybe run the H OB further into bass, and wanted to gain insight from the experienced.
My system: two 12" Rythmik servo subs in DIY sealed boxes below 65Hz in mono, and per side: one 18" Faital 18HP1010 baffleless dipole on a swing from 65 to 275Hz, twin 8" from 275Hz to 1.8kHz (bottom 8" on U baffle to reach to 275Hz) and AMT above. Active 4-way, digital xo and room correction.
Happy with Rythmik sealed subs and thought about adding two more to get a distributed bass array. And I came across GR Research/Rythmik OB servo subs in H or W baffle, getting great comments, that can be xo up to 200 or 250Hz. Looking at their model with dual 12" per sub.
And this has me thinking about these options:
  1. add two sealed Rythmiks to the existing two and play 20-65Hz.
  2. add two GR Research H baffles to the two sealed and play all of them 20-65Hz. I wonder if mixing sealed with dipole bass, despite both being servo-driven, would be detrimental.
  3. add two GR Research H baffles and play them 20-200Hz with the two sealed reinforcing 20-65Hz. Getting DBA below 65Hz. 2x12" have less surface than a 18", probably noticeable from 65 to 100Hz or so, but the GR have servo so allegedly more controlled/articulated than the 18".
  4. add two sealed Rythmiks to the existing two and play 20-65Hz, and later add two GR Research doing 65-200Hz with a shallower H or just a panel. This might in turn drive me to replace the 18" with a 12" dipole which eventually would allow to raise the xo to the mids from 275Hz to 400Hz or so.
The room: it's the living room, with little flexibility as to placement. It's 30x16x2.4 feet high, divided into two sections (dining and living room) by a wide sliding door. Current subs and speakers shown in blue, and the listening seat.
The grey squares show where the two new sealed subs would go, or where the sealed subs would go should I get OB subs. OB subs could be placed somewhat away from the corners, but baffle would likely be about 30" from front wall.
What are your thoughts about OB vs sealed bass below 65Hz?
And baffleless 18" vs twin servo 12" on a baffle in 65 to 200Hz region?
Thanks in advance!
speakerparts.co - CNC flatpacks / custom + public designs
Anyone interested in a build but put off by lack of CNC or wood skills, we provide CNC flatpacks for any simple or medium complexity builds.
The website is in works (Custom CNC cut DIY speaker cabinet flatpacks baffles MDF Baltic Birch – SpeakerParts) but you can message me for ordering. Welcoming trial users. 🙂 We are in the KC area so shipping should be reasonable all over the US.
Transistor Ft as function of Vce?
To build the perfect amplifier that we all want - we need to know how transistor Ft varies with Vce. So we can optimise.
Bob Cordell's book (p22) says Ft droop at lower Vce at hi current, with a "Vce ... as little as 5V ... current ... several amperes" in an example.
The On semiconductor datasheet for the MJL4281A (fig.9) has the reverse, with better Ft at Vce=5 than Vce=10 for the entire current range shown (.1A to 10A)
A net search didn't show much accessible research. I even overworked my brain with the original Gummel_Poon paper in the Bell Systems Journal.😱 I suspect there's several different effects that interact in a complicated way. Any pointers to more information or an explanation?
Or it could just be a mistake in the datasheet.
Edit: Which is what it is.
help with jl audio e1200
When connecting the amplifier it does not turn on and consumes more than 7 amperes without load, disconnect the loads one by one and detect a possible short, all the power section transitors were disconnected, and the equipment turns on, a mosfet transistor was discovered in short j111, The detail is that when you reconnect the power transsitors and stop turning on the equipment, when making some voltage measurements it is detected that in the gate terminal of the section that is fed from the positive +35 v of the mosfet there are 15 volts, some suggestion.
TPA3122D2N Solderless Breadboard
So I'm working on a project that's fairly complex overall with many components and one component is a power amplifier stage after a PCM5102 DAC. I'm basically retrofitting an old radio with entirely new "guts". I'll write more about it later, it's quite an adventure, but one component is a power amp stage. I've not built an amp before but I was aiming for Class-D mainly because they run cool and so don't need a heatsink.
For this project, I'm trying to go all-through hole. The radio isn't huge so I don't need to worry about getting loads of power from the amplifier. I found the TPA3122D2N, but I'm worried it's actually not powerful enough, so I wanted to breadboard it to test it with the speakers in the radio before I build (and pay for) a complex PCB. I'm leveraging the existing transformer which provides around 13.5V DC once rectified and smoothed.
I bought all the components needed (basically the list from the TPA3122D2N datasheet) and started building. But I can't generally get the thing to make any sound. This is probably because it's on a solderless breadboard. I did get it to make sound once(!) but then I turned it off and when I powered it up again, nothing. All I get is a rhythmic clicking at about 4Hz.
My schematic is attached, although I've since switched from BTL to SE (by providing L/R on the inputs and splitting the outputs accordingly) since my input signal will be SE from the DAC.
This is tearing my hair out! Can anyone make some suggestions, or should I give up with the solderless breadboard?
Akai AM2450 Volume in one channel fades
recently picked up an Akai AM2450 and has issue of audio in either channel fading out and sounds distorted while it does. When this happens its only to one channel and can be either.
turning up the volume temporarily fixes it.
I thought it'd simply be dirty volume pot and or dirty contacts in the speaker relay. However the issue persists.
oh and wow what a relay! the thing should have a clear casing to show off it's internals lol
The caps look original, unless they were replaced long ago and in entirety.
The volume pot had a ton of oil residue, it has a particularly open design. but I don't think the issue is either of those components. its been cleaned.
Particularly because the issue can be one channel or the other.
all other adjustments sound and work fine; balance, bass, treble. switches sound fine too; input, Loudness, Mono / Stereo, A/B speaker.
It has watt meters, which work when speaker switch is off...however when the fade out issue happens
it can be seen in the watt meter...it slowly decreases in magnitude.
The pots for bias look rather suspect / are completely open design.
Any ideas?
SSE sounding muddy. Could I have something connected wrong?
Hi all. I built an SSE awhile back, and I'm finally getting some free time to listen to it on the regular. Right away, I've found that it doesn't sound very good. Muddy. Almost muffled sound. I've tried other amps with the same speakers and they sound clear as a bell, so I suspect maybe something is up with my SSE.
Mine is built in the standard configuration. It has motor cap and choke. Tubes are EL34, and the output transformers are Toroidy TTG-EL34SE.
To those who might be willing to help me figure this out: What information do you need from me? Would photographs help? Any other part numbers you need? I'd love to get this sorted, as I think this amp has lots of potential. So I'm happy to provide any additional info.
Thanks in advance, Tubelab gang!
The Output stage querries !!!
Gentlemen,
Iam looking to build an amplifier for myself with IPs(considering spooky, ComSuMo, Wolverine, GLA surviour) & OPs on different board so that I can interchange the IPs only incase required.
Iam looking for 2 options:
1. Lateral Mosfet stage OPS
2. BJT OPs stage
As a DIY starter want suggestion on OPs:
a. If I consider Slewmaster OPs with drivers changes to Lateral mosfets(not sure if anyone has tried this way) what could be effected in terms of sonics ?
b. Has anyone tried https://www.synaesthesia.ca/OP-stage.html ?? Or any better suggestion with L-Mosfet OPs is requested.
Thank in Advance,
Suman
Idss tests of LSK489 and LSJ689
A few months ago I ordered a few JFets from an internet site that had limited supply. I only ordered (4) LSK489 and (4) LSJ689. Results for Idss of the LSJ689 had a wider range than I expected (and the high Idss get noticably warm). There is no way to order grades like other parts such as LSK170, LSJ74, LSK389.
So if you need 2 pairs, I guess the safest thing to do is order 4 😕. I'm not sure changing ccs or source degeneration resistors is a better way to make up for good matching..
There's another supplier of Linear Systems that has many more parts in stock. Maybe better luck with them? Could others post results if you have them available?
LSK489: 3.41mA (A), 5.46mA (B), 6.04mA (B), 7.80mA (B)
LSJ689: 6.47mA (A), 7.10mA (B), 11.76mA (B-C), 14.56mA(C)
Attached picture of test setup, Vgs=0V, Vds=10V, measured using ammeter V+ to Vd for Ntype and Vd to V- for Ptype.
Also attached spice sim for all grades as reference.
Which of these ICs can be swapped out with the OPA2134?
There is/was a shop in Idaho that was doing upgrades to the DBX 3BX series one dynamic range expander. One of the things they did was swap out ICs for a much better OPA2134. It was a drop in replacement, no mods to the surrounding circuit needed. Other than that I can’t get any other information. This is what is in the unit:
10 - LF351N
8 - LF353N
10 - RC4558P
1 - LM301N
3 - unknown, the markings have been removed.
My best guess is the RC4558P. Could it be possible to replace the LF351N and LF353N with the OPA134 and OPA2134? I really wish I could get more info on this.
Is link a schematic, but the only one I can find isnt the best quality and needs to be zoomed in on. The images I post get fairly degraded.
Thank you,
Dan
Pioneer BOFU 4 sale
found a pair of the Pioneer BOFU drivers in the office today. thought they were gone.
anyway, is anyone interested in buying these? the surrounds are good. they were installed in a pair of the hedlund cabinets & then returned to the original shipping box from parts-express.
$50 + shipping. probably via fedex or ups.
if any are interested, i'll post some pics.
thanks.
Mutual coupling question
I found this in some ElectroVoice product literature:
"When two speaker systems are placed side by side, the woofer cones “mutually couple,” causing the two systems to act as one system with twice the effective cone area at very-low frequencies, giving an additional 3-dB increase in maximum acoustic output. Mutual coupling will occur when the frequency is such that the center-to-center distance between the two woofer manifolds is less than about one-half wavelength."
I have two identical subwoofer cabinets, placed side by side in a corner of my listening room. They are crossed over actively at 90 Hz. I've been trying to get my head around the mutual coupling thing as it applies to these boxes. Here are the numbers:
Center-to-center distance = 44.7675 cm
Estimated Speed of Sound = 34500 cm per second
Frequency = Speed of Sound / Wavelength
For Wavelength = 89.535 cm, Frequency = 34500 / 89.535 = 385.3 Hz
What I get from this is that mutual coupling only occurs above 385.3 Hz. I wouldn't call these "very-low frequencies"! What am I missing here?
EDIT: I did a search here and now I'm even more confised....
I found this formula:
Fo = c/(d*sqrt👎)
Where
"c" is the speed of sound in the air in metres per second (normally 343 is used, but can vary slightly according to air temperature and humidity).
"d" is the distance in metres between the two speakers
"n" is the number of sources.
Fo = 343 / ( .447675 * 1.4142 ) = 541.77 Hz
Help?
Thanks,
dooper
Help please - Sub sounds *blah*
I've have a Stryke Audio HE-15 in a 22" cube with two 18" PR's. My box (purchased pre-made) is roughly half of the box pictured (actual interior dimensions are around 22"x22"x22") in the following link - thanks "greg", it's hard to find these specs nowadays.
link for subwoofer
I have a Mackie m2600 to power it (I bought this used). Here is a link for the specs:
link for mackie
I have the Stryke's 3ohm dual voice coils wired in a series.
My problem with this is the output.
With the mackie in bridged mono mode, I do not think I am getting adequate output. The amp shows that it is giving it all she's got (the front led's light up to the "clip" level), but the sub is barely moving...maybe 3/4 inch excursion. And the sound level is certainly lower the my SA 12 in a 1ft^3 sealed box with a 500w digital amplifier.
The mackie has the low pass filters off and the crossover at 120hz.
What's going on here? I have access to a much smaller amp (around 150w) and I only have rudimentary tools (a Radioshack db meter and multi-meter).
Am I expecting to much?
If not, what steps should I take to test the driver, passive radiators, box design, and amplifier? - I'm gonna assume that the box design is OK at least.
Any help would be much appreciated!
Thank you,
Chris
Anyone done a custom PCB for a small low fi BT/AMP before?
i've been watching a few youtube videos (like probably most of you), which were actually non audio related and noticed how many people seem to be getting PCB's and custom chips made, which made me think of has anyone done a small bt amp for a lowfi build?
i've bought a few CSR8645 Amplifier Boards and other variants of them (QCC3008) and due to the size find it difficult to firstly solder onto, but trying to cram it, plus a battery and a boost coverter all into a tiny build.
So my question would be, has anyone done a custom build, if yes, would it be hard to do for somebody who doesnt know how (but keen to learn) and how hard would it be to integrate something like a TP4056/7 1S BMS and a boost coverter (3.7 to 5v) etc?
I have a few builds which are basically 3d printed 500ml beer cans with a downward firing 2inch full range and i want to use the amp as it has the ability to be modified through the BT chip and use custom EQ settings (and it is small).
example
Csr8635 dual 5w bluetooth 4.0 /4.1 amplifier board audio bluetooth 4.1 receiver module with call function Sale - Banggood.com
Info on mercury rectifier DCG1000-01
I have some mercury rectifiers that I have not planned on using. But I am tinkering with the idea of a 'show off' amp just for demonstrating the fascinating side of tubes, and tube glow is a part of that.
One set I thought of using is a pair of Philips DCG/1000-01. But I cannot find any data on filament voltage and current.
I do find the DCG4/1000, this has 2.5V/4.8A filaments. So can I assume DCG/1000-01 is 2.5V but only 1A?
Any one here know?
As for using mercury rectifiers. I know some of the risks, probably not all, I know one must apply heater power long before HT (at least 1 minute?). Is there a tell tale way of knowing when one of these are bad, and even if they may catastrophically self destruct?
If I want to dispose of them, where do I drop them off? I guess the local dump has 'dangerous goods' section and will send them to where they belong. I dont intend on selling them, just because I dont like poison going to who knows where...
Or am I over reacting?
thnx for comments
Siemens F2A tubes
4 pieces of F2A tubes for sale $400usd OBO , one of the pair is used for a few tens of hours for an experiment. The other pair is plugged in for tests, and then stored. Selling as it is, no returns. Pm me to check shipping cost to your location. Will ship from Singapore.
WAV playing - Advices for beginner
Bit-Perfect playing WAVs - Advices for beginner
I'm just taking the first steps to get good stereo music from my WAVs through an entry-level system made up of a digital interface, a (digital) stereo amp and a pair of passive speakers running Windows 7 x64: no audio NAS, no media streaming, no music server intended.
I'm passionate and experienced about listening to music, both live and played within the walls of a room, but through my PC I have almost no experience at all and even if my PC-based system is currently an entry-level one I would like to (understand and to) get the max possible quality sound from, so I started reading and still reading articles and discussions, but now I'm a bit confused and would like to receive authoritative confirmations or even denials about some basic principles.
Running a capable software player is the Bit-Perfect playback applicable to WAV files?
If so, how do you get it?
I'm just trying 2 players that I like: Album Player (free) which I really like and JRiver Media Center (commercial) which I like enough, both with strengths and weaknesses and both with the ability to use the ASIO driver supplied with my audio interface.
I think I understand that if you use ASIO driver (or WASAPI too) for the Bit-Perfect playback then both Windows mixer and volume control are just bypassed and no longer functional, but I still can't get it: is the above true also playing WAV files?
Definitely, how to get theoretically and practically the best possible sound quality from my system playing WAV files under Windows 7?
Many thanks in advance for any appreciated addressing.
ONIX Power Amplifier Model OA701 (OA-701) Schematic wanted
This amp works fine, but there is a hot spot on the amplifier PCB. The reason are two very hot transistors from front-end in a E-line envelope like this outline:
https://www.diodes.com/assets/Datasheets/ZTX652.pdf
For check the reason in detail I want to have a service manual or at least the schematic diagram.
Under
History | ONIX - Hi-End audio products from england since 1979
there isn't to find a download portal for pdf schematics and service manuals.
Who can upload the schematic?
More URLs:
https://www.audiovintage.fr/leforum/viewtopic.php?t=37135 (images)
Onix Audio - Wikipedia
Emilar ew15-8a (altec style woofer) .?
Hey
Plan to build a old school large 2-way, perhaps petite Onken, or altec 612, or similar. Found a pair of Fostex H320 wooden horns (tips for a 1” cd going low would be nice, or if building an adapter to 1.4” is more clever, would probably work).
There are some old Emilar ew15-8a 15” woofers available, together with Emilar Ec175 and upgraded Emilar crossover of 800hz.
From some old threads, it sounds like the Emilar elements are compared favourably to Altec etc., but do any of you know? Or even have data for especially the woofers? (I read fs of 21 hz, likes large cabinets, was in a 220l box).
Maybe worth a gamble? Or better keep looking for a 414 / 416 / ? (Really hard in Sweden..)
Thanks in advance 😬
What would you do if you lived forever?
What would you do if you lived 3000+ years?
Read an interesting article: assume all medical issues are solvable and nobody dies of illness or old age problems. You keep the mind and body of, say, a 30yr old, indefinitely.
How long would you live then? The surprising answer came from life insurance actuarials: about 3000 years. That is the average life expectancy in our part of the world, based on only accidents, suicide, murders, that sort of thing.
Then I though: what would I do with so much time? Build your own home, a brick a day? Spend 30 years to learn all about amp design, design the ultimate one and build it including designing and building each part? Take up a study and spend 50 years to learn all there is to learn about, say, the Roman empire including doing an in-place decade of archeological digging?
Would you jump off the roof top due to sheer boredom after a couple of centuries?
The sky would be the limit!
Jan
Halfler P230
I have a Halfler P230 amp. Even at very low volume, my speakers sound like they have bass breakup. I tried other speakers, and they do the same thing.
I checked the large power caps (10000uf 75 volts) with a VTOM. Infinite resistance. If indeed the caps are bad, would that cause this problem??? How doe the amp even work if these caps are bad?
Kairos Three-ways
I’m considering doing a build of Jeff Bagby’s Kairos 3-ways. I have built the CJD Khanspires, a Dayton RS series 3-way, and like them. I’m now interested in building something with a bit higher end drivers and a bit more exotic cabinet construction would be fun too. These will go in a 12x12 home office, so I don’t need huge output, but…
Has anyone built these, and if so what are your thoughts? Would you recommend an alternative for full-range, high quality sound smallish room?
Test results: wow/flutter & heavier mass platter
I recently purchased a mint condition 1961 Empire 208 turntable. Everything was in excellent condition, sans the belt and rubber mounts. I replaced the belt and rubber mounts. I also re-lubed the motor thrust plate, turned the thrust plate over to the fresh side and inserted a new precision ceramic ball in the motor thrust plate. The platter spindle has a steel ball bearing which needs to be replaced, but I have not done so yet.
Using the iphone RPM app to record speed and wow/flutter (I can not vouche for the accuracy of the RPM app, but its the best I have), I recorded several measurements for speed accuracy and wow/flutter. FYI: I use a Long Dog Audio LDA Quartz Regenerator power supply which keeps a steady voltage. The Long Dog Audio unit allows the platter speed to be adjusted easily with 0.01 increments. So, I was able to lock into 33.33 RPMs and it did not fluctuate during use.
Using the stock platter (aluminum which rings like a church bell), the iphone RPM app recorded a wow & flutter measurement of 0.16 - 0.18%. This range was consistent across 3 measurements.
Then, I added a 60 pound platter from a prior DIY project to the top of the stock platter. The 60 pound platter was centered within 0.001" TIR. With the added mass, the wow & flutter measured 0.06 - 0.08% (again measured 3 times). The only variable between the measurements was the platter weight.
Also of note, with the stock platter and motor off, I spun the platter and it continues to spin for a few minutes. I used a stethoscope to listen for bearing noise. None detectable. In all my years of using a stethoscope, I always detected bearing noise until today. Quite a nice feat for a stock 1961 turntable.
Then, with the 60 pound platter added to the stock platter, I once again spun the platters and used the stethoscope. Bearing noise was clearly audible. The bearing noise was cyclical which indicates that the sleeve bearing is where the noise is occurring, not the steel thrust plate. The sleeve bearing noise was likely caused by a slight imbalance in the platters weight distribution and thus would shift the bearing laterally and create the bearing noise.
So, where does this leave us:
1. 60 lbs incremental platter mass reduced wow/flutter by 50-66%.
2. Heavy platter needs to be appropriately balanced to no longer cause the sleeve bearing noise.
The 60 lbs platter is not suitable for the current setup (see photos), as it was taken from a 17" OD Gates CB500 transcription table. So, I am considering a new high mass platter and bearing.
Meanwhile, the stock papst motor purrs like a kitten, albeit with the fan noise that is inaudible at the listening position.
More to come.
Pat
Looking for a data sheet for DNA Sequence Midrange
Hello,
I'm having trouble identifying the part used in the DNA Sequence for midrange reproduction.
From DNA Sequence Speakers dipole open baffle woofer high efficiency point source array midrange tweeter treble loudspeaker
"5.75 inch polypropylene sandwich cone midranges made in Denmark - possibly the best midrange driver ever made!"
I bought 25 of them a few years back, and I'm trying to build with them, but having trouble figuring out the right crossover point and enclosure arrangement.
The inductance is vanishingly low, and the transient response is very good, and the SPL is around 92dB if I recall correctly.
Thanks in advance for any help.
BK Precision 2120 gone blurry
I bought a used BK 2120 scope about 7 months ago, and its been pretty faithful actually up until this afternoon. I know how to use it and have been using it on average about an hour per day since purchase.
The trace line for both channels just today quadrupled in height. Focus cannot get the trace line as sharp as it was even just this morning. Nothing has changed at all afaik but then again dealing with old equipment. The scope still works otherwise but very annoying not seeing that sharp trace.
I opened it up but everything seems very clean inside.
Foreign object to me. There are no pots for focus fine-tune adjustment within either.
Anybody know how I might service this?
freeDSP V2.0 (ADAU1452) developement thread
If you don't feel like searching the thread..
PiDSP is on GitHub:
Sourcefiles[/QUOTE]
There is also manual:
PiDSP manual
Final(hopefully 😀) version is under way. You can watch the progress in development branch in Git repo.
I'm also pondering about having a batch of PiDSP boards profesionality made.
If you are interested, drop me a PM.
Hello everybody 🙂,
few weeks ago I've discovered the freedsp project and found it to be very interesting... but the ADAU1452 seems so much more potent dsp.
So I got in touch with the creators and joined the team with focus on new version with ADAU1452. I've been pondering about it for some time now, reading datasheets, researching, playing with possibilities etc.
Now it's time to open development thread and ask you about your opinion, feedback, and ideas, so we can make the next version as good as we can.
Flood of questions and ideas follows..
The general idea:
DSP, DAC, PSU - each on its own separate board, connected via wires, maybe backplane. ADC is not in my scope at this moment
PCB width 100mm - enclosures available, length 80mm(half eurocard) or 100mm, we will see.
Smaller builds could fit into extruded enclosure (hammond,fischer), bigger in rack
PSU board:
talema 70000K +- 15v for opamps and 48V(via voltage doubler) for phantom - no reason not to add it. will be useful with possible ADC board
Another transformer for digital part, maybe with double secondary - second winding for analog circuitry - PLL, DAC ref. etc.
I haven't made my mind about it yet. Any suggestions?
DAC
Stacked TRS 6,3mm - only way to fit 8ch to 100mm wide PCB, 8ch - why not 4x2ch? Big, expensive, I'd like the project to be accessible, and I like KISS principle. I've narrowed down DAC choices to following:
PCM1690 - cheap, available, even got samples somewhere...
AK4358 - comparable with PCM, number-wise
dual AK4413EQ, higher performing pin compatible alternative available AK4414EQ - really nice spec.
AK4458 - new part, isn't available yet, would be nice to use new stuff in the design though. I'll try to get samples.
Opinions (and experiences) about/with DAC chips highly welcomed. My life is too short to try everyone of them, so in the end I'll just pick one and go with it,If you have something to say about them, please do.
Why no ESS stuff? I'd like you to be able to buy all necessary parts at usual outfits (digikey,farnell,mouser...).
Yes, you can buy Sabre in single qty, no problem, but the shipping is prohibitive. And world is full of sabre dacs.
DSP board.
All IO should be brought out. Clocks on UFL connectors, others on 2.54 headers, signal/ground, signal/ground... SPDIF on BNC.
We could add MCLK input, its just a few additional parts and might be useful for some.
Number of I2s lines is limited, 4in, 4out more channels is accessible via TDM. I'm considering providing isolation on I2S lines, so you could use the board directly with BBB as a source.
Would be nice if one could plug BBB directly into the board - you even could program the dsp with it.
I believe it's enough for a first post. Opinions, advices, questions?
At this point it's just bunch of ideas, in the end it could be single board with XLR outputs.... Nothing is set yet... well probably DSP, oscillator, and LDO for PLL are set 😀 ... What I meant is if you think that single board(or XLR, or DAC XYZ) solution is better, say it and add why you think so 😉
Thanks for reading
Pitrsek
P.S.😛lease feel free to notify my about my spelling/grammar mistakes via PM.TY.
Possible to do feedback from before OPT on PP amps?
OK, long shot here. Taking FB to the VAS from the primary side of the OPT (output tube plate) is a simple matter in SE amps but is there a way to take feedback from the primary side to the VAS in a PP amp? If you take it from just one output tube it might be OK for normal signals but I am thinking that things would go completely nuts when there is an overload or even class AB operation. Reasonable assumption? Any clever tricks or just bite the bullet and buy a scope?
sherwood s 6020 CP has no audio output?
Hello! I'm trying to troubleshoot my preamp, one day it was working fine and the next day it had no sound! I'm very inexperienced with this sort of thing, and this preamp is pretty old, so google wasn't much help. I've checked the fuse, cables, and plugs, and I'm about to take it apart to clean the inside. Hoping there's a simple fix that I'm missing.
Denon AVRX5200W/6200W
Hi everyone!
Troubleshooting SMPS with output voltage fluctuation from 4.8V to 5.0V, spikes to 5.2V and back to 4.8 every 2-3 seconds.
Replaced with brand new: both optocouplers U6501/02, rectifier D6515, U6503 IC.
Primary voltage is stable 160V on C6506.
T6501 secondary side is stable AC voltage.
Diodes tested OK. Caps OK. Resistors OK.
Suspect D6524, but not sure....🙁
Any help is greatly appreciated!
DIY amplifier: OPA 1611 + Bipolar transistor
Hello,
I am not an electronic engineer and my english is poor.
Sorry for my mistakes.
I work on this amplifier for a few month with MicroCap 12.
Here is the schematic, distortion with 1Watt output and phase diagram.
What is your opinion and your comments?
The power supply will be a SMPS from HYPEX + - 64V
Single Ended Triode Class A2 Driver Design
One approach to gain more output power for single ended triode amplifiers is to drive the output tube to positive grid for class A2 operation. I found two different circuits on the Internet. One uses 12AT7 and the other uses IRF610.
Can someone with more experience comments on these two approaches?
The 12AT7 seems to be biased quite low. I am not sure it can deliver 4 mA for the 6S4A tube to operate at full A2. Can I increase the bias or change the tube to something like 12AU7 or 5687?
The IRF610 for 4P1S (4P1L), on the other hand, was biased at 42 mA. It looks like good enough to drive the 4P1L. However, what are the design criteria for this MOSFET? Is IRF610 linear enough? Are there better new MOSFET for this application?
Transformer took a hit
Hi everybody !
I'm new here. I didn't find a place te present myself, so i do it here.
I'm a jazz/rock and so on guitar player from Belgium, always playing on tube amps for years and years.
One of my amp took some rock and roll on the side, and the transformer took a hit. on the side. (See picture below.)
My questions are the following : do you think the transformer is broken ? If not sure, do you think i can try to switch the amp on without damaging anything else than the transformer if it's broken ? (NB : the amp wasn't switched on when it took that hit and has never been switched on since.)
I don't have much of a peny to ask to a technician to repare it right now, but i still would like to play so hit singles if it's still working.
Thanks a lot in advance for your time and help.
Best everything you like,
Y.
Locating holes for tube sockets
Apologies if I’m brain dead and this turns out to be a stupid question. I’m building a tube amp and need to punch holes in the metal top of the chassis for 9 pin tube sockets. How does one precisely locate the holes? I have two PCB’s with two nine pin tube sockets on each board. I can’t just lay the sockets on the metal and trace around them because the PCB’s are in the way. If I lay the sockets on the metal without the boards to locate them, then they won’t line up when attaching the sockets to the PCB’s. I’ve been pondering this for weeks and can’t envision a solution. Any help will be greatly appreciated.
GU-50 screen and suppressor grid resistors
Hi guys,
currently I'm designing a class AB2 PP amplifier working with two pairs of GU-50's. The operating point will be the one in the rightmost column at page 9 of the Telefunken EL 152 datasheet. My PSU only provides 290 Vdc for the screen grid supply, though. In order to increase efficiency by decreasing the tubes' internal plate resistance, the supressor grids will be fed from +12.6 Vdc.
The datasheet doesn't read values for the screen grid resistors and especially not for the suppressor resistors, as this isn't a very common way to go. Which resistor values would you recommend, please?
Best regards!
Whats the advantages of "Distributed Port" enlosure
Hello Folks,
I have an old and deteriorated bass reflex speaker with 8 inch driver tuned in 50hz and want to make a new enclosure
instead of make an exact copy the box i want to try some experiments
i want to try to make the same box with same tunning but instead of use a single port i want to use multiple ports like the project i saw in this old article
my question-
whats the benefits and disvantages of the distributed port enclosure compared to a single port bass reflex and why they arent so popular
Need a little help with crossover design
I'm new to speaker building and I have two main questions, is it advisable to do a series parallel crossover in a 4 way speaker cabinet, and is this a good layout for my crossover in general, I'm not quite sure of the inductor layout. Also, I know the Caps aren't optimal but they were what I could afford at this time (I will be replacing them later).
Projects by fanatics, for fanatics
Get answers and advice for everyone wanting to learn the art of audio.
Join the Community
508,507
Members
7,922,553
Messages
Filter
Forum Statistics
Threads
407,892
Messages
7,922,553
Members
508,507
Latest member
Boc610
